Finishing Boxes,
Finishing Boxes,
Finishing Boxes,
Jorge Casta�eda
>Hi Guys,
do you finish the inside of boxes as well as the outside, or leave it as is?
If you finish the inside, what do you use?
Thanks!
Jorge
Re: Finishing Boxes,
>jorge
I just use paste wax on the inside. I do the final sanding with the wax and 400 grit paper. I learned that from Chris Stott and it seems to work well for me. I also do the inside of the lid the same way. I use my standard lacquer finish on the outside.
Ken Grunke
>Generally not a good idea, since the smell of most finishes may linger inside the box. I always leave mine unfinished inside in case people want to store herbs or other edible goods in them.
Eduardo Sarmiento Hall-Lima Peru
>Well Jorge I use the same thing in or out for mi boxes sanding sealer and wax or shellac because they are to be used and will not dirty the small jewels that are put on the inside ED
Jorge Casta�eda
>Thanks John,
Do you spray or brush the lacquer?
Jorge Casta�eda
>Thanks Ken,
I had that thought, that it will smell for a long while, but in the other hand, the inside could get dirty, so I did ask.
Jorge Casta�eda
>Gracias Eduardo,
I will try the sanding sealer and shellac, that works well in the inside of drawers and boxes are a similar case.
>Jorge
I use Deft clear Brushable lacquer thinned with equal amounts of lacquer thinner. Apply with a Bounty paper towel. rubb it until it won't spin off and then turn the lathe on and buff it with another paper towel. If I get streaks I add just one drop of finish to a clean spot on the towel and rub the bad area while the lathe is on. this works kind of like french polishing and cleans up the bad areas.
Lately I've been using the Beal Buffing system to finish my boxes but these are mostly boxes for friends and time isn't a factor.
Jorge Casta�eda
>Thank you John, I really appreciate your help.
John Trant (aka Boxes-n-Bowls)
>I use a mix (emulsion actually) of tung oil and shellac applied on the lathe much as John L Described for his Deft lacquer finish. Again as John suggested, the shellac/oil mix essentially replicates the action of a French polish. Multiple coats work well. The oil enhances grain figure and the shellac seals the grain. The oil does have a residual odor (one that I think is fresh and nutty but my wife thinks is musty) but that will go away with time. Alternatively, I will use neat shellac or Deft much as John described. A year or so ago, I used Danish oil (Watco) under carnuba wax.
John
Jorge Casta�eda
>Thanks John, another path to explore.
