small item turning
small item turning
Jack Guzman from Maine
small item turning
>Hello, I don't visit this forum much.I own a grizzly basic 36"lathe.I got it to make handles and such. I've turned a few crude bowls,a couple mallets and alot of tool handles. I use a few parting tools,a 3/4 in gouge for roughing in and a 1/4 in bowl gouge. Plus I have a few flea market skews,gouges and scrapers.
I need to know what I need to turn small knobs or spindles.Is there an accessory for holding a small item on one center that doesn't cost more than my lathe? When I make a knob now,I put a long piece between centers and turn the knob out of one end and then cut it off.But,I can't get tiny knobs that way.My setup is just too crude. Help anyone?---Crackerjack
Re: small item turning
>Jack
These days I chuck up a small scrap in my 4 jaw chuck and true it up. then I drill a hole in the center . I remove the piece and run a screw the size that I need through the hole from the back side. Then I epoxy the screw in place. Now put this back in the chuck. drill my blank and screw it on the homemade chuck I just described. Then I turn the knob.
Before I had a chuck I would do the same thing by gluing a piece on a waste block. The only difference would be that I would use a longer screw. You do need a faceplate that has a hole in the center.
You can glue your knob material directly to the waste block and just turn the knob but then you have to drill the hole for the mounting screw after words.
JamieDonaldson
>Try doing it the old fashioned way-turn a semblance of a Morse taper on one end and then drive it into the spindle nose for final turning of knobs, etc. It helps to use the tailstock as much as possible until you are ready to make the final shaping cuts on the end, then part or saw off the taper.
>Thanks John,I think I can do that.---Crackerjack
Re: small item turning string out
gtools
>cherry shaker knobs...stringing-out gives the advantage of fine tuning the porfile.....gtools
Richard Allen
Re: small item turning *LINK*
Richard Allen
>Oneway has a small screw chuck that slides in your MT of your headstock spindle. It is designed to use the sanme screw you will be using for mounting you knobs and can acomadatem sloted, philips and square head screws.
The chuck works great. Use the tailstock for support for most the the turning. Move the tailstock out of the way to finish off the top of the knob.
Oneway small screw chuck
Re: small turning better string
gtools
>new at resizing pics, another try......gtools...
John U - Charlotte, NC
>A small screw center might work well -- here's one for under $10 you can pick up from your local Sears store, or try www.craftsman.com and search for item #00929846000.
Craftsman Screw Center
Arch
>Where in Maine,Jack? Anywhere near Bucksport?
Most machine shops will give you broken drill bits with Morse tapers. Cut off the twist leaving a short stub of the shank. Grind a flat on the stub so that a piece of small nail lying on it lengthwise just reaches the circumference. Voila! a cheap small pin chuck.
Or grind off the shank flush with the taper, If it's too hard, heat red hot & let cool slowly to soften. Drill and tap for a small hanger bolt. Viola! a oneway screwchuck knockoff!
For very small knobs etc screw a Phillips head into the small blank, (could be the screw that will be used to attach the knobs) Turn by driving with a phillips bit held in a Jacobs chuck. Secure with the tail center.
There's no need for me to use one word when too many will do. :) Good luck. Arch
Loose Tenon
>Another method that will work well is to make a compression chuck out of some scrap hard wood with a morse taper on one end. The other end has a taper to it also and the center is drilled out to accept the doweled end of the knob, slightly undersized. Saw across the drilled end in two places so that when you make a ring to slide on the chuck it can compress and hold your work. You could prepare your knobs to rough shape between centers, in the string fashion, but make the dowels accurate. Cut off at the dowels and insert them in the chuck, tap up the ring to tighten and finish the shaping. If you have access to Ernie Conover's lathe book there's a good diagram of it in there. I make napkin rings this way, only I use the external part of the chuck and bring up the tail center to expand the chuck.
HTH Loose Tenon
>I'm in Newfield. It's a small town on the NH border in northern york county.The top of the bottom.---Jack
Thanks everyone
>Wow! I should visit more often. You people are very accomodating. I hang out on the hand tools forum because that's what I'm mainly into.
Your responses answered my question quite well. Thanks---Crackerjack
