CA Experience
CA Experience
CA Experience
jonathan spool
>I've been using CA glue for a while now, both as an adhesive, and a filler. Great stuff.
Last night I decided to try it, for the first time, as a finish, on a 10" walnut bowl. WOW, was that an experience. That stuff put out some heavy duty ammonia! Breathing was tough, and eyes were a burnin! To you veterans, I must sound like a dope, not having known about the toxicity of CA, but having learned about it in this manner etched it indelibly in my brain!
I'll be sure to do this outside next time.
Has anyone used the "Fume free" CA that I have seen advertised?
Re: CA Experience
Re: CA Experience
darrell
>Another caution: don't spray accelerator on your fingers if you have CA on them. Will make you hop around quite a bit, gets hot!
Re: CA Experience
Re: CA Experience
>Johnathan
I don't use CA as a finish very often because it's just too expensive and the fumes are nasty. When I do use I put the dust collector hose nearby to pull the fumes away. I have a friend who used a fan over his shoulder.
I many have to give it another try after watching Tom Fortenbery use CA to finish the outside of a vessel. The trick was to use Cotton Batting as the applicator and keep the glue bottle near the applicator so as the glue started to run out on the applicator you could immediately apply more while the piece was still spinning.(slowly I might add) The trick Tom said is to apply one coat from top to bottom without stopping. If you stop or run out of glue it will produce a line that's very difficult or impossible to get rid of.
I've only used it on pens and I use a piece of wax paper as my applicator.
Re: CA Experience
Re: CA Experience
Russ Fairfield
>Are you sure it was Cotton Batting, and not Synthetic Batting??
The polyester fibers in the Synthetic Batting is better because the cellulose in cotton and paper acts as an accelerator for the CA glue. There is no reaction with the polyester.
Re: CA Experience
Re: CA Experience
Marc Phillips
>I use ScotchBrite pads.... to stop the drips and distribute the CA.... seems to work great, and a lot better than the plastic bags and wax paper I have tried in the past.... I haven't had any problems and the pad lasts a very long time...
Marc�s Site
Marc Phillips
Warner Robins GA
Re: CA Experience
Re: CA Experience
>Russ
I just looked at my notes. He did say Polyester quilt batting but if memory serves me he also mentioned that cotton batting would also work but had a tendency to make the CA harden in the batting.
Re: CA Experience
Re: CA Experience
jonathan spool
>Thanks everyone NM
