vb36 question
linda
>Hello. I am curious about the capacity of a vb36 lathe. What is the largest diameter bowl that you could turn on one?
thank you
vb36 question
linda
thank you
Re: B-A-
>T-H T-U-B
Which Terry will confirm for you shortly with a link.
7 foot 6 inches *LINK*
TDaniel
>with the optional floor stand; 36" with the standard toolrest beam. Now if you want to go bigger then you have tp place the lathe on a pad. Basically you can turn anything that will fit between your floor and your ceiling. Weight limit will be by your own guts, not the machine.
http://www.thebowlmaker.com
Re: Correction
>H-O-T T-U-B [for 4 or more]
