Maple Box w/Faux Granite Resin Casting
Ron in Drums PA
>This is an experiment and would like some feedback. I still have the tenon on the bottom so this is a work in progress. I'm probably going to make the bottom smaller so it matches the grain.
3-1/4" x 2-1/4" by 1/8" thick, still wet watco.
Thanks for looking
Re: Maple Box w/Faux Granite Resin Casting
Darryl Hansen
>Ron where did you get the granite casting stuff. I have been looking for a replacement for Inlace but hve run into a blank wall...?
Earl
>I think it looks really nice. You have a winner there. I would agree that the narrower bottom following the grain would look better.The way it looks now, the bottom half doesn't really flow.
Earl
GeeSeaWhy
>You can bring the bottom in a bit, but beware of making the box look unstable or top heavy - how much weight does the insert add to the lid?
It's too late to do it with this one but consider putting a small bead on the lid and/or the base, next to the join. It helps disguise the slight mismatches that occur when the lid and the base inevitably move - at different rates.
Graeme
Ron in Drums PA
>Here you go
http://www.eti-usa.com/consum/castresn/castresn.htm
http://www.eti-usa.com/books/castinbk/castidbk.htm
Ron in Drums PA
>That's a good idea about the bead. I still can burn two grooves, one below and one above, I'm going to do that, thanks.
I only used about a 1/4oz of resin and eyeballed an equal about of faux granite filler. After turning, I'd guess +/- 1/4oz of weight is added to the top. It actually has a good feel because of the extra weight.
