First bandsaw question (long)
Rick Strawser
>This is addressed to the "average", home/garage, hobbist turner.
What size bandsaw are most of you guys using?
My major interest is Windsor chair spindle turning,I suspect any 14" 1 1/2hp would do.
However,I have attempted some green wood bowl turning. Hollow forms and segmented turning looks interesting also.
I have cut one set of bowl blanks with a small electric chain saw and a chop saw (not very pretty)
Lathe is entry-level Jet 1442 1HP, 14" over bed with a swivel headstock.
I suspect my limit would be vessels 5-7" diameter
8-10" high?
While we all would like a 20" Minimax, that just isn't going to happen.
What say you gentlemen?
Re: First bandsaw question (long)
MikeinCapeMay
>I have a 14" Grizzly. I added a riser block and when the 3/4 hp motor bit the dust (after years of use) I replaced it with a 1 hp also from Grizzly. I routinely cut blanks up to 12" diameter (that's my lathe capacity)and up to 12" ht. I also resaw on this same saw, various hardwood to just shy of 12" in height. My buddy uses the same setup though with theoriginal 3/4 hp motor to supply his 3520a, so he's cutting 20" diameter and up to 12" ht. Of course diameter isn't the gauge, but thickness is and this saw with the riser block has handled everything that I've fed to it. I'll add that I use R&D and Timberwolf blades. I believe the saw, a G1019 is now selling for $320.00, the riser block is an additional $40. The saw received the Popular Woodworking magazine Editor's choice, for whatever that's worth. I'm happy with it.
My bandsaw ascension...
Peter Teubel
>I started with a Relient DD90 14" bandsaw with riser block. Pretty much the same as a Jet or Delta, but with some "rough" edges. It was always struggling with thick cuts, so I swapped out the tired 1hp 1750 motor with a Delta 1.5hp 3450 motor. It had a jack shaft so I was able to slow it down a bit, but it was still running about 30% faster than stock.
Cut thru BIG wood like butter. Never stalled. But all that power was wearing out ALL the bearings at an alarming rate. So my increased throughput was somewhat offset by the constant repairs.
Finally, I just decided I need to have a bandsaw that just plain WORKED and was designed for cutting big stuff. Got a Jet 20" 2hp unit and its been a real pleasure to use. Everything on it is heavy duty...not industrial heavy duty (that would be the DoAlls, Tannowitz, and Crescents)...but heavy duty enough for the serious hobbiest or small production shop.
Oh the joy of being able to adjust the blade guide on the fly without having to adjust the blade guide bearings everytime!
Marc Phillips
>I have been up and down the bandsaw scale, and now have the Grizzly 17" 2hp... and really like it. I chose this saw for the power and the 12 1/4" resaw height... plus it uses the roller guides, and has lots of extras... I was nervous about Grizzly tools, and this was my first Grizzly purchase, and I am very, very impressed with the quality and fit/finish of the tool, and it performs so smoothly that it's hard to tell it's on. I think it was $825 delivered.....
Good luck to ya...
Marc�s Site
Marc Phillips
Warner Robins GA
Tony Reynolds Newark, OH
>I agree with Marc's findings. I have the 19" Grizzly G0514. It's a very nice saw. Well built, smooth running, and lots of power. I think I gave $925. Add a Timberwolf blade and it's a saw for a lifetime. If you're getting into the bowl/ vessel turning vortex, get the biggest saw you can afford. Cutting large green blanks or logs takes a fair amount of power to cut efficently. Good luck in your search.
Tony
Lyn J. Mangiameli
>I would recommend obtaining the Ittura Design catalog to help you gain an understanding of bandsaw design and options. His "catalog" is as much a manual and source of reviews as it is a product display (and that product display is probably the best performance enhancements you can make to 14 inch saws). Louis Ittura probably knows more about the Delta 14 and its clones than anyone since the original designers. He also offers a lot of information pertinent to larger saws, and offers his recommendation for what saws and specific criteria to consider in both the 14 inch and larger sizes. The catalog also has direct critical comparisons of old and new Deltas, and 14 inch Deltas and Jets.
His catalog/manual is free, but alas, you have to call to get it. If you are lucky, you will get Louis himself and be able to ask him a few specific questions. The phone number is 1-888-722-7078
The bandsaw question (A very long answer)
Russ Fairfield
>The following are some of my experiences and philosophies on using the bandsaw. Feel free to disagree.
These comments are directed toward the 14� bandsaw in general, but are specific to the 14� Delta saw and its clones (Jet, etc.) because these are the most used by woodturners in their shops and studios. Instructions for tune-up and adjustments of the saw are presented in another article.
Recommended Reading
There are several excellent sources of information on blade selection and operation. Any disagreement between them is in what is important and the details.
� Mark Duginski�s book, �The Bandsaw Book� is usually available from Home Depot, Lowe�s, and all of the mail-order stores. It has been around for years, and is considered �the� authority on the bandsaw. The basic information is good, but newer developments are not discussed and the illustrations are out-of-date.
� Lonnie Bird�s book, also called �The Bandsaw Book� is a newer (1999) reference that uses the same recent vintage tools that most of us have in our shops.
Two Internet sites are also excellent sources. If you don�t have a computer, find someone who does, and make copies because these are worth reading.
� Suffolk Machine, makers of Timber Wolf blades at: www.timberwolf1.com
Click on the title of, �Vertical Woodcutting Band Saw Information�, and �The Six Rules Of Sawing�. While you are there, get their telephone number so you can order the best bandsaw blades available.
� Highland Hardware at: www.highland-hardware.com
Go to the Online Magazine from their Home Page, then go to the title under the Shop Tips heading in the index.
MY OPINIONS ON�.
Buying A Bandsaw � Which One?
There are several decisions to be made when buying a new 14� bandsaw � Delta, Jet, Ridgid, or other; closed or open stand; with or without a riser block. The answers to these questions will depend on how it will be used and how much you want to spend.
The 14� saw is an assembly of compromises that were made to produce a saw that would fit the needs of the most woodworkers. This has generally been successful. However, finding a bandsaw that will make precision cuts in dry wood while having the capacity to saw large bowl blanks is asking too much. We can configure the saw towards one extreme or the other. Trying to do both with the same bandsaw will always sacrifice the precision cuts.
� General Quality
Delta stands alone with its lower guide assembly that places the blocks less than �� below the table surface. For all practical purposes, Jet and Ridgid are identical to the Delta, except for the design of the lower guide blocks.
The Jet is available with the enclosed-stand while the Ridgid is available only with the open-stand.
The quality control of the Reliant, Grizzly, and the other clones of the Delta is out of control, and the buyer takes a chance that they will get the occasional good one.
� Guide Blocks
The only notable difference between Delta and the others is in the lower guide assembly. For a saw that is used for making polychromatic assemblies or similar work that requires smooth accurate saw lines, my preference is the 14� Delta. I am a believer in the old wisdom that says, �The closer the guides are to the work, the more accurate the cut and the better the finish.�
However, for a saw that is used for cutting thick bowl blanks from green wood, I prefer the Jet because its lower guide blocks are almost 2�� below the table, providing more clearance for the removal of sawdust and trash.
� Closed Stand or Open Stand?
The closed-stand on the Jet is more solid than the Delta because it has included an additional stiffener plate between the saw and the stand. The Delta saw will move as the top of the stand flexes, but this can be fixed with a piece of �� plywood.
As provided by the manufacturer, the open-stands are as rigid as the closed variety (the Delta open stand is the more rigid), and the open-stand is more stable because of its larger �footprint�. This is helpful when wrestling large heavy blocks of wood to the saw table. When the open areas of the stand are enclosed with pieces of plywood, the result is superior to anything provided by the manufacturer.
The motor, belt, and sheaves are more accessible on the open stand. Maintenance on the saw drive and belt isn�t something that we will do very often, but the design of the closed-base insures that it is something that we will never do.
� Riser Blocks
All of the 14� saws are sold with a 6� standard cutting depth that can be extended to 12� through the use of an accessory �riser block� that is inserted in the joint in the saw frame.
As woodturners, we are in love with our �riser blocks�, BUT, there is a price for the additional capacity. The riser block adds another point of misalignment because there are now two (2) joints in the frame, and the additional height increases the flexibility of the frame and that amplifies any unbalance in the top wheel. If you are using the saw for precision sawing such as �polychromatic� assemblies (a fancy word for �segmented�), DO NOT use the riser block. The saw is capable of smoother and more accurate cuts without it.
� Horsepower
The woodturner who installs the riser block should plan for a larger motor as part of their purchase of the bandsaw. All 14� bandsaws share the common problem of inadequate horsepower for sawing greater than 6� thickness. This is especially true when sawing green wood. You might want to consider a larger motor if you are sawing bowl blanks that are thicker than 6�. Keep in mind that the cost can become as much, or more, than that of a larger saw with the capacity built in.
� My Recommendation
From the previous discussion, it should be obvious that I consider the extra cost for the enclosed-stand a waste of money. Buy the open stand and enclose it with plywood. Then add a shelf between the stringers and place at least two (2) sandbags on it. The added weight is definitely a benefit, particularly when the saw is mounted on a mobile base.
Some saws may not be available with the 1-horsepower motor in any configuration other than with the enclosed-stand. I would still opt for the open stand, and then use the money saved to buy a 1.5hp motor for it.
If you are going to use the saw for precision work, get the Delta, primarily because of the lower guide assembly, and do not install the riser block.
For sawing bowl blanks and green wood where capacity is more important than precision, get either the Jet or Ridgid with the riser-block, making the decision on lowest cost. Plan to replace the motor for an increase in horsepower.
If the saw will be used for both purposes, the Delta with the riser-block is the better saw, again because of the lower guide location. Precision sawing will suffer from the addition of the riser-block, but that is the sacrifice that must be made when using the same saw for both purposes. The larger motor may also be required.
Buying Blades
Timber Wolf brand blades with 2 to 24 Teeth Per Inch (TPI) are available from Suffolk. You can pay more, but you can�t get a better blade.
Timber Wolf blades are superior for three (3) reasons.
First, they are consistently sharper out-of-the-box than any other brand. A new blade should feel �sparkling� sharp when you run your fingers across the teeth. I have received competitor�s blades that felt like running my finger across a comb � no bite.
Second, the tooth �set� on their band stock is more uniform than most other brands. That leads to a smoother sawn surface, and more efficient use of the motor horsepower.
Third, their welds are better than most of the others. The weld should be straight, strong, smooth, and ground to the same thickness or slightly thinner than the blade. Lennox makes comparable blades, but I have had problems with crooked and weak welds by their suppliers. I can tolerate having to work on a thick weld before using the blade, but I will not accept a poor quality or crooked weld.
You are fortunate if you have another source that can meet all three of these requirements.
Blade Width
Unless there is a need for sawing a small radius, most woodturners have little need for anything other than a �� wide blade. A narrower blade doesn�t have the stability for accurate sawing at an acceptable feed rate, or the strength to prevent it from bowing while making deep cuts. A 3/8� wide blade would be an acceptable compromise. Both widths are available with a variety of tooth profiles and from 3 to 24 teeth per inch (TPI).
Number of Teeth
There are three (3) rules for selecting the teeth per inch (TPI) on the blade. Since these rules can be conflicting, the best choice is a compromise between them. It�s up to each of us to determine how much and where we are willing to compromise.
� Rule 1 � Number for Performance:
For best performance, there should be 8 teeth in the wood. Fewer than 6, and control and vibration can become problems. More than 10 and the gullet area is too small to remove the sawdust. The proper loading should fill the gullet area of the tooth to 75%.
� Rule 2 � Number for Feed Rate:
Most people feed the saw too slowly. We should maintain a feed speed and pressure that will slightly overload the tooth gullets. Up to a point, this overload dampens vibration of the teeth and improves the finish. I once heard Sam Maloof say that the best feed rate is when the motor starts to stall. That�s overloaded!
I judge the load by the sound of the blade in the cut. When it whines, it is vibrating, and the finish is bad. The best cutting condition is when the blade is pushed to where the whine just stops. If that doesn�t stop it, the problem is usually too much tension in the blade.
� Rule 3 - Exceptions
There are probably more exceptions than there are applications of these rules, but they do work on most common hardwoods and softwoods. Very dense or resinous woods obey no rules.
- The Compromise
Obeying the rules could result in a feed speed that is too fast to accurately follow a layout line when we are doing precision sawing. But, if we slow down our feed rate, we don�t load the teeth enough to dampen the tooth vibration, and we get a poor surface. So, if it doesn�t burn the wood, a blade with more than the recommended teeth in the cut will solve the problem because the tooth gullet area is less, allowing us to use a slower feed rate while still filling the gullets with sawdust.
A better solution would be to reduce the blade speed to a level where we could follow the layout line with the recommended number of teeth. Unfortunately, a variable speed bandsaw is an option that is not commercially available.
There is no compromise available to us we are when sawing thick bowl blanks. We install a blade with 2 or 3 TPI, the largest tooth and gullet area available, and don�t worry about such things.
Experience
Our use of the two blades that have become the accepted commercial standards for the 14� saw will verify the first rule. The best performance and smoothest surfaces with the 1/4 X 6 TPI blade is usually found in wood that is between 1�� to 2� thick. The � X 3 TPI blade makes its best cuts in wood that is about 4� in thickness. In either case, there are approximately 10-12 teeth in the cut. Cuts can be made in thicker or thinner wood, but the blade�s performance is generally not as good.
Blade Speed
The 14� Delta saw and all of its clones have a 3,200 surface feet per minute (SFPM) blade speed with a 1750 RPM motor and the stock 3� and 6� pulleys. This is too fast to get an accurate cut and a good finish on most 4/4 and thinner wood, and can cause burning in Cherry and Maple. A blade speed of 1,800 to 2,400 SFPM would be more suitable for these conditions. Changing the pulleys is not a practical solution for a saw that has many different uses. A 1�-hp variable speed DC drive motor is available at a cost of $550. Or, we can make our own mechanical drive through a jackshaft and stepped pulleys. Unfortunately, the cost of new step-pulleys, the jackshaft, and bearings could be almost as much as the DC motor if we have to rely on commercial sources.
Either option would allow us to fit the blade speed to the sawing task, including the slower speeds required for sawing aluminum and brass. An open stand on the saw is best suited for drive modifications because of the limited space in the closed-stand for installation and adjustment.
Resawing
A higher speed might be appropriate, but the 14� wheel diameter limits the maximum blade speed to 3200 SFPM. A higher speed would �throw� the blade away from the front of the top wheel. It would also require a proportional increase in motor horsepower on a saw that is already lacking in power.
The �� X 2 or 3 TPI blade performs quite well in most common hardwoods of 4-8� thickness, and the feed rate is usually limited by the motor horsepower. The blade will have difficulty clearing the sawdust from a thicker cut, and overheating can be a problem in dry wood. A common problem with sawing thick wood is that the blade gets hot and loses its tension above the top guides. An occasional light spray of water above the top guide will prevent this problem when it occurs.
A light spray of kerosene or Pam will keep the blade relatively free of resin buildup.
Sawing Green Wood (up to 12� thick)
The �� X 3 TPI blade, and the 3,200 SFM cutting speed works well for most green wood, and the blade is adequately lubricated by the water in the wood. The PC type blade from Sufflok is the best tooth profile that I have used. Suffolk also makes a 3/4� blade with a wider kerf that is useful in soft or �fuzzy� wood, but the wider kerf requires more horsepower than most of these saws have available.
Horsepower is a problem with any cut that is deeper than 5� or 6�. Replacing the existing motor with a 2hp Baldor will improve the performance, regardless of the blade that is used, for sawing and green wood . The Baldor motor is more efficient than the stock motor on any of these saws, and the horsepower delivered to the blade will be greater than the numerical increase.
Again, increasing the blade speed would be even better, but that would require a saw with large diameter wheels and an even larger horsepower motor.
This is not a response -
Mark Kauder, Phenix City, AL
>it is a book.
Great information Russ.
Mark
