A55 Smoothing Plane
new lathe
new lathe
new lathe
Fred Le Bail
>I think I bent the spindle on my Shop built lathe. My Dad built me this lathe about 7 years ago and never had any problem 'til started trying bowls last year.
It is 10 x 48 on 6' channel iron, can turn 20" so don't really want to part with it.
Have a machinist looking at it but he is not a wood turner so he is not too concerned...But I am!
I am looking for a good General lathe, all my chucks and attachments are made for General 160 so they will interchange ,but you "Spinny Guys" opines are welcome.
Thank you,
Fred
Re: new lathe
Re: new lathe
Bill Howatt
>Nothing wrong with any General lathe (I have a 20" 260) but if you are going to use your 1"x8 attachments you are likely to be restricted to a smaller swing lathe. I think General only offers the Model 160 with a 12" swing now.
Most big lathes use 1-1/4" spindles or metric equivalent (oneway) or larger. Also, these machines often use heat-treated spindles to increase their hardness. If you put a large wet block, particularly if it was out of balance, on your shop-built machine the 1" non-treated (??) spindle may have been to weak.
As much as I like General, I think I would consider some other options in the price range instead of a 160. Have a look at the Nova DVR, Jet, Powermatic. Other than the DVR, sourcing the Jet and Powermatic in Canada seems to be difficult. Maybe somebody can update this comment.
Bill
Bill
Re: new lathe
Re: new lathe
Bill Hale / The Wood Spinner
>Your comment was " I think " ???
If you have been happy with the home built why not be SURE the shaft is bent ?
It could just be a bad bearing.
Have a new shaft made and re bearing what you have.
Unless of course you just need a reason to buy a new and better lathe. Look to the Oneway 2436.
Good turning and be safe
Bill
