dust collection
dust collection
dust collection
DWFII
>I have a very small shop and limited space. I turn small projects as a hobby--pens, candlesticks, handles, etc....small bowls in the future, hopefully.
I wear a Resp-O-Rator (?) when I turn and especially when I sand and finish. But I've noticed that I am creating a lot of very fine dust that seems to get everywhere.
I'd like to set up a dust collector that will deal with the fines...both during sanding and after sanding. I can sweep up the heavier stuff--that I'm not worried about--but the small stuff is becoming a problem I never anticipated. But I simply don't have room for a big bag and barrel cartridge system. I could afford it but the space is not there.
I've seen Grizzley and PSI and a few others offering fairly compact dust filter/air cleaner boxes that can be set near the lathe to collect dust as it is being created. Do these work? Are they sufficient?
My shop space is so limited, I have to store my lathe under a bench...I would appreciate any advice with regard to how to deal with the dust problem--economically and space conscious-wise.
Assume I am completely ignorant of anything to do with dust collection--it's close enough to true--and I welcome advice.
Thanks
DWFII
Re: dust collection
Re: dust collection
Stuart Johnson
>I'm not really sure about how effective it is but I use a box fan with a furnace filter. Place it behind and up as close to the work as comfortable. Have it blowing away from the work. The fan pulls the filter up tight so here is no need to attache it. It does seem to do a fair job but should not be confused with an actual aircleaner or dust collector.
Re: dust collection
anything is better than nothing...
TDaniel
>but I like the hanging units like JDS.Harbor Freight had a small one on special a couple of weeks ago for $100. I have a new Jet for sale for $165 but the best is the JDS at about $275+ or -. They are very effective in cleaning the floating dust from the air. Another option is eliminating dry sanding. I do most of my sanding with Watco Danish Oil thus eliminating dust and getting the oil deeper into the wood at the same time. Sand it in to about 400 grit and let it dry for a week and then sand from 400 to 1200, again with oil. Let us know if it works for you.
TD
Re: dust collection
Ric Taylor
Re: dust collection
Ric Taylor
>Penn State has a dust collector on sale right now at their website. I think it's $39 off the regular price.
