Vacuum Chuck - thanks Steve Worcester!
Greg W. in NC
>A few days ago, Steve posted a message, with a link to making a vacuum chuck out of MDF. I had made a couple of small chucks from solid maple, but not a larger one. Tonight I used a vacuum chuck made by gluing 3 pieces of MDF together, and then drilling / tapping them to fit my shaft. It worked perfectly! It allowed me to finish my largest bowl to date - a beautiful ambrosa maple bowl - 12" x 4". (max swing on my lathe is 12.5"!) Thanks Steve!
Re: Vacuum Chuck - thanks Steve Worcester!
Steve Worcester
>Your welcome. And thanks to Johnny Tolly for writing it.
sroxberg
>I've been following, and have created, some of the recent vacuum chucking threads. I just discovered a great source of MDF. It's stair treads. Only six dollars and they are 4 fee by 1 foot. But the nicest part is that they are 1" thick. Just thought I would pass this information on. This weekend I'll be making some MDF chucks.
sroxberg
>Where did you get the tap, I'll need a 1 " by 8 tpi?
Greg W. in NC
>I think I got it at Wholesale Tool Company. Most of the machine tooling companies will sell them. You need a tap that fits your spindle, of course. thanks for the tips on the stair material. Is that MDF or HDF?
Juergen
>Try Ebay. I found a couple 1 1/4"x8 taps a while back. You'll also need a drill that at least 1/8 to 3/16 smaller than the tap.
I've also used this technique to make face plates up to 12" works great. Most of the industrial supply houses (MSC, Enco, McMaster-Carr)carry the taps but they're more expensive that Ebay. Good Luck.
