How close is to close
Dustmaker Mike
>Hello all
I am cleaning up my shop again and moveing things around. I was wondering how close can I put my Jet 1236 to the wall? Right now I have it about 4" away from the back of the motor is this far enough? Thanks
Re: How close is to close
So you can walk behind it :-)
Ron in Drums PA
Ric Erkes
>Take your tool with the longest handle and make sure you can swing it through it's fullest arc.
Say for example, you want to work under a rim, the tool might be need to be in a position almost straight out from you.
Ric
MikeinCapeMay
>If you have the space, 90 degrees to the wall is great!
Thanks I will play
Dustmaker Mike
>around wih it a little more or maybe get a moble base for it. I am trying to put any tool against the wall if it will work for me. I have a 68 Mustang I am going to be bringing into the shop for a little while and need the center space.
Re: 1236 Mobile Base
>plus ballast and an on-board tool rack. Worked well in my shop where (as you can see in the pic) most everything has to be mobile. Lathe was actually bolted to the base and the 200+ lbs of sand (in box) and block, cut down on my "Dances With Lathe" routine.
Mark
That is a neat idea
Dustmaker Mike
>do you have better pictures of the tool holder some were? I just hung one on the wall it works, but I am not happy with it. Is it moble also?
Re: A neat idea #1
Re: A neat idea #2
>Swing limited to keep out of harm's way from 2 pivot bolts attached to the tail-end legs.
Worked so well that guy who bought the lathe insisted on buying that too |;-}}
Enjoy
Cool one more project on
Dustmaker Mike
>my long list of todo's Thanks
Re: Cool one more project on
Whit
>An interesting idea. But (there's always a "but" isn't there) I'm not real happy with the idea of reaching over spinning wood to get another tool. Seems like this is asking for trouble. My preference would be to mount something like this so it swung around to my side of the lathe at the tailstock end. I think that would be handier and, more importantly, safer. Just a thought.
Whit
Re: Glad You Mentioned That
>Whit,
The rack was set up to be out of the way for bowl-work and above the level of the lathe's max swing even on spindles BUT
It also swung about 270* to 90* to the bed so that if you were doing spindle work, the rack was in arm's reach of your right hand.
Mark
