imbedding wood in resin
>I've been trying to imbed 2 small goblets in acrylic resin and it's fighting me. I used system 3 mirror coat. What seems to be happening is the heat from the curing epoxy is causing bubbles to surround the goblets and obscure them from view.
At first I thought it was the epoxy reacting with the plastic cut I poured it in so I tried paper cups which have worked before. It did the same thing again. This time I decided it might be the epoxy reacting with the finish I put on the goblets.
I made 2 more goblets and left the finish off. I filled the cup half full and let it harden with the goblets suspended. So far so good. Mixed up some more and pouree it over the goblets. Came back in an hour and they were covered with bubbles. I'd post a photo but my son has my camera right now.
I'm going to make 2 more in the morning and cover the goblets with a thin layer of the mirror coat and let it dry. Hopefully this will seal in any moisture or whatever is reacting with the epoxy.
If anyone has any good suggestions I'll check in the morning before I try again.
Re: imbedding wood in resin
Russ Fairfield
>Try pulling a vacuum on it. The vacuum will do wonders at eliminating the bubbles. One more reason for having a vacuum pump.
A 1-gallon glass jar is a good vacuum chamber. Put a hose nipple in the lid. Put the container of epoxy in the jar, screw on the lid, and attach a vacuum hose.
>Russ
I've actively considered the vacuum system because I use this epoxy for other purposes and it should be totally clear for this. If what I try this morning doesn't work I'll be out looking for a jar. Here in Tennessee it shouldn't be hard to find a gallon jug. Just head up to the nearest creek where you see some smoke and try not to look like a FED.
For another oddball project I had to glue some cloth to an irregular shape. I cut the corner off an 8x10 Zip lock bag and taped the hose from my vacuum pump into that corner. Inserted the wood and cloth in the bag and Zipped it up. Turned on the Vacuum and came back in an hour. Perfect. This would be a great system small veneer projects.
