Eight inch grinding wheels 1700+rpm.
Jack Dolan
>Eight inch grinding wheels. Suggestions for buying new finishing wheel. I use it for gouges and scrapers only. Brand? Grit? Thanks. Jack Dolan Pgh.
Jack Dolan
Re: Eight inch grinding wheels 1700+rpm.
TDaniel
>I use a blue wheel, 80 grit for my gouges and a blue 60 grit for my scrapers. This seems to be a good all around combo. The 80 gives a fair edge but the edge has some "bite", kinda like a steak knife. I can get an edge sharper on my Tormek but many times it doesn't cut as well. Just my little opinion.
TD
JamieDonaldson
>Jack- I like the combination of AlO(white wheels)in grits of 60 and 120-I'm partial to Nortons but have also purchased other brands from Woodcraft.
Doug Trembath
>Jack, the Norton SG wheels marketed by Craft Supplies is the outstanding choice for most pros, from what I've seen. Jerry Glaser had some input into their design, as I understand it, and uses them exclusively. Pretty expensive for the initial outlay, but they are gradable similar to the Tormek stone, and if used judiciously, will last a long time. Paired with a good solid grinder, it's the cat's meow.
Doug Trembath
Studio in the Woods
Whit
>I use 60 and 100 grit aluminum oxide (white) wheels. The 100 is Norton, the 60 is who knows. Came with the 8" Delta Variable speed grinder. Sources of grinding wheels are Craft Supplies, Packard, Lee Valley and many others.
Whit
Jack Dolan
>Thanks to all for the response to my grinding wheel question.
