vacuum pump
johnnie lewis
>can anyone tell me where i can buy a vacuum pump and give me some advice on how to make a vacuum chuck thanks in advance
vacuum pump
johnnie lewis
Re: vacuum pump
sroxberg
>I just bought a Gast pump from the Surplus Center for $89 plus shipping. It's 220 only, but otherwise the same as the $300 dollar pumps.
I'm still getting mine wired in so I can't comment on how it works let, but it was priced correctly.
Re: vacuum pump
Brian MacDonald - Olympia, Wa
>I bought the same pump, works great, check your email for plans for a chuck.
Re: vacuum pump *LINK*
sroxberg
>Did you set up a vacuum tank or go directly to the lathe? The Joe Woodworker site has designs for a tank that I plan to use or build when I go to veneering, but on the lathe should I build one?
Joe Woodworker
Re: vacuum pump
Bill Hale / The Wood Spinner
>Johnnie
I am buying a rebuilt Gahst from a fellow that works in their plant. These are factory rebuilt at $ 150.00. E mail him for all of the info. These are one of the best and the price is right for the specific pump. He ships prepaid so the $ 150 is delivered
bernie@hydraulicparts.com
Mine should be here in a couple of days.
Good turning and be safe
Bill
Re: vacuum pump
>Bryan
Would you please send a copy to me also.
Thanks Bill
>John,
You find a very good article with plans disgrames and, I think, sources at the link below. Click on the "Technical Tips" block and scroll to the vacuum section.
Mark
GWG
On the way
Re: vacuum pump
>directly to the lathe, the pump is rated for continuous duty and seems to be working just fine
Try Bill Noble
Darryl Hansen
>Here is a link that will answer your questions. He is good to work with...
http://snmp.labridge.com/~wnoble/forsale/vac-pumps/gast.htm
Mark Kauder, Phenix City, AL
>I bought a used Vacuum pump on Ebay for $100 including shipping.
Our very own Al Crandall did an article (link below) on building your own chuck. I have built many chuck for our club members using this plan. Simple and cheap.
Me too!
John Cahall
>Could I get a copy also? Tks.
Re: vacuum pump
William Westbrook
>Bryan
Thanks William
Re: vacuum pump
Steve Worcester
>There is an article on my web site written by Johnny Tolly.
He outlines how to make them out of MDF and they will thread right onto the head stock with no face plates.
http://www.turningwood.com/mdfchucks.htm
Thanks - Steve Worcester
www.turningwood.com
Re: vacuum pump
Greg W. in NC
>Steve,
Excellent article! I've made quite a few chucks along this style with harg maple, but they are limited somewhat in size. I like the idea of using the MDF.
It is just so easy to tap / thread a wood blank on your shaft, and turn to whatever size you want! I also use the adapter on the tailstock to make those threads match the headstock shaft, so the chucks can be used on either side.
Thanks again for posting this article!
