Need Segmented Help
Stuart Johnson
>I need some help on a staved hollow form. I tried to align the vertical spacers. The bottom and middle two start to align but are off about 1/8" as they work their way around. The top collar is way off as you can see from the picture. I'm sure this is something mechanical but don't know what needs to be done. Would he rings being slightly oval and turned round cause this? What is the best way to prevent this problem? It seems to me with the compound staves requiring such tight angles (13.06 miter with 82.56 blade tilt on one) it would be hard to not need some touch up on the sander. Any help would be appreciated.
