Tear out from Sorby texturing tool
Tony Manella
>I recently turned a small bowl from a piece of elm. I added a textured area to the outside using the sorby texturing tool. The texturing was done with the tool at about a 45 degree angle. When I applied the tung oil finish it caused the textured area to get some dark blotches. I'm assuming this is due to the scraping rather than cutting nature of the tool. Is there any way to avoid this problem (sanding sealer, different tool approach)? The elm piece will get the textured area painted gold with black highlights to hide the blotches but I want to avoid this problem in the future. Thanks.
Re: Tear out from Sorby texturing tool
Brad Adams
>Tony,
This may not be the answer you are looking for but... I'ts been my experience that the texturing tool and elm don't mix well. If you don't get the effect you are after on this piece I'd try this on a different wood. Good old sycamore is what I test texturing tool ideas on.
Brad in Benicia
Re: Tear out from Sorby texturing tool *LINK*
joaz hill
>I have had a lot of problems with this tool as well. It seems to tear at the end grain. It does not texture the end grain as uniformly as the side grain. I really don't use it much anyone because of frutration, but would be glad to if someone could instruct me on a better way to use it.
http://www.maine-web.com/woodturning
Brad Adams
>I�m still experimenting with the tool but I think it�s a great way for someone who is too lazy for pyrography or coloring to dress up a boring bowl.
And yes I was drinking a glass of wine when I took the picture, but I did take it upside down on purpose. Really.
Brad in Benicia
