Dumb hollowing ?
Dumb hollowing ?
Dumb hollowing ?
William-Bethlehem
>Hey all,
I am (im)patiently awaiting the arrival of my hollowing system. :)
However, in anticipation to lots of practice, I had a question on hollow forms that have a contrasting "top" "finial". ie, a walnut form with a maple top.
How do you go about doing that? do you glue the two pieces together much like a lamination and then turn the outside/hollow inside or is the top put on after the hollowing is done and you blend it in and drill a hole?
Thanks in advance!
William
Re: Dumb hollowing ?
>This is just me but I hollow through the big hole and when the piece is done carefully cut a rebate in the top and true up the hole. Then I put the contrasting wood in and turn it.
On really fragile pieces I turn the contrasting piece on a seperate waste block and then glue it onto the piece afterwords. This has also saved me when the piece warped too much while hollowing.
William-Bethlehem
>Thanks John.
So it's kinda like a doing a lidded box except it's a permanent lid with a hole.
William
GeeSeaWhy
>I posted photos of one of my pieces in early May. Search for "Box Elder form - take 2 *PIC*". Much as John said, I hollowed the box elder and the rosewood collar separately. Afte drying the box elder, I turned a recess to fit the collar and glued it in. Advantages of this approach include having a bigger hole to hollow through and not having to be careful about messing up the opening. And the final opening can be small enough to prevent anyone getting a finger inside to find out how sloppy I was with the finishing cuts :-)
About the only drawback is you have to be careful not to make the recess too big for the collar.
Graeme
