A55 Smoothing Plane
Spalted silver maple hollow form (PIC)
Mike Schwing from Maryland
>Lightly spalted. About 8" wide by 6" tall. Pretty thin for me, about 1/8-3/16" walls. Warped a bit, doesn't sit quite perfectly straight. Finished with lacquer and buffed on wheels.
Critique welcomed. I like the form overall but am not totally happy with the curve upwards towards the opening. Might have been a bit better if it were flatter for a distance and then curved more sharply upwards. Next time maybe.
It checked a bit while drying on the lathe so I didn't go nuts finishing it to perfection. However, what appear to be tool marks near the rim in the photo are not.
Re: Spalted silver maple hollow form (PIC)
Dave Peebles Lyons, Ohio!
>Hello Mike,
I like this form very much. I think the top is just right. I do many forms very much like this one, so I may be biased a little. But I am in love with this beauty.
Nice work,
Dave
Dinyar Chavda
>Mike:
It's hard to tell with these pics as to whether your self-criticism is valid. It may be that the form would be better if you flattened the top, but that may not be necessary in this one. If yuou want to, shoot a couple of pics head on (these look like they are from a higher elevation), and post them.
I noticed that you have made this comment (re flattening the top) on a couple of pieces. I find that there are certain things that I do also, which I wish I didn't, but my gouge almost seems to have a mind of its own. :-)
If you really want to see what the piece would look like with a flatter top and steeper mouth, turn it initially the way you usually do, but hollow out the inside to about 1/4 to 1/2", or even thicker. This will allow you the flexibility of looking at the piece when it is "done", and then decide whether you want to flatten the outside, or take out more meat from the inside. Does that make sense? I have had to do that for some forms which I have problems with---it takes longer to do, but I can usually et to where I want to.
Sorry about the rambling, but I can blame it on the hour. :-)
Dinyar
RevDoug
>Mike,
I'm with Dave on this one. I like what I see. The wood is absolutely beautiful. I really like the effect of the wood wrapping around itself. Keep up the good work. Your hollow forms have been fun to watch.
Turn 'em round,
RevDoug
