200+ woodworking book reviews
Kelton tool handle review
Mike Schwing from Maryland
>A few months ago I asked for suggestions regarding making my own handles. I was frustrated with the standard handle(s) that came with my tools, as I was running out of handle on deep work and desiring a bit more mass. I wound up buying a Kelton large tool handle instead. Here's what I think about it.
First, a bit about me and what I turn with will help - I'm a short guy (5'5") with a tall lathe. (PM 3520a). At first I thought this was going to be a problem, but as it turns out, the combo is perfect. I also use the Ellsworth grind almost exclusively and am now getting into hollowing as well, both tools mostly require a horizontal approach. This all comes together great for me as the tool approach, the height of the lathe, and the lack of my height wind up putting the tool handle in my armpit very naturally, and giving me great control over the tool. I also like to work off of the end of the lathe whenever possible as opposed to standing aside it.
That out of the way - I bought the large Kelton tool handle designed for their hollowers. The tool is a 2 piece job, and it totals out just under 24" in length, with the smaller, 5" section joined to the longer one via a 1/2" diameter steel rod. When the extension is not used it can hold a 1/2" diameter tool. Both the extension and tool steels are secured via two allen screws.
The business end of the Kelton hollower accepts a 3/4" or 5/8" tool steel and the handle is hollow the entire way through. This allows you to vary the protrusion of your tool steel from the handle to affect a different tool balance. Again the tool steel is held in place with two allen screws, but they protrude from the handle about 4mm, something that generally annoys me. They don't get in the way but they're always on my mind. They do, however, aid in knowing which way the tool flutes or cutting edge is facing if you align the flutes with the screws.
For use with my Ellsworth grind tool steel the handle is absolutely marvelous. The additional weight of the handle makes the tool move more smoothly, keeps vibration down, and doesn't tire my hands out. When used in shear scrape mode, the add'l heft is a great bonus as is the add'l length, as I can rest the handle on my thigh and move along the workpiece much more smoothly and controlled. I do not normally use the extension with the bowl gouge, but have found that when hollowing the extension is invaluable.
I've also discovered something you hollow form guys probably already know - an Ellsworth grind gouge in the long tool handle is GREAT for hollowing once you reach the max diameter of a workpiece, better for me than a typical hollowing scraper type tool, and you don't need to see the gouge in action to avoid a catch - the little allen screws point to "up".
Overall I'm VERY pleased with this handle. Its comfort rivals its utility. The ability to modify the tool balance and weight is priceless, and the ability to have a gouge in each end of the tool is a great feature. I've never felt like I wanted to modify the grip's diameter or material, it feels very natural.
I don't think I'd like it quite as much if I couldn't rest the tool handle in my armpit easily, the weight might tire my arms out prematurely.
I'm definitely glad I bought this tool vs. making one myself.
Re: Kelton tool handle review
JamieDonaldson
>I hate to throw cold water on your enthusiasm, but be very careful with that long handle under your armpit- I know turners have dislocated arms with a catch. I have enhanced one of my Hosaluk handles (same as Kelton) by filling it with lead shot- makes a great roughing gouge handle.
>Thanks for the safety warning Jamie.
I'd bet that you couldn't come up with a scenario in life, or at least in this turning thing, where someone hasn't suffered an injury from anything you can think of.
I would suggest to you that this is a safer position than most, as it allows such a good hold on the tool that you can easily resist most of the forces that would cause a catch.
If I said I held it down near my hip somebody would chime in saying they knew a buddy who blew out a hip that way.
But as I said up front, thanks for the safety heads up.
Catches? Why?
TDaniel
>Mike, I have read your posts about the handle position that you use and your comments about catches. 99.9% of catches can be eleminated with a one day class on this subject. I wish you were closer to north Georgia. While you are out jogging in prep for a run just drop by here and we'll show you how to eleminate catches. We did a topic a few months back on elininating catches, I wonder if anyone benefitted from this or if it would be worthwhile to do it again?
TD
no catch issues here
>Terry, thats not what I intended to say. I don't really have catches anymore. I can feel when they're about to happen. Its not an issue, really. I was telling someone the other day that I can't really recall the last bad catch I had, and only intended to make a slight reference to why I thought the possibility of them happening was decreased with the tool hold I employ. The only times I recall recently having anything at all like a catch was stupidly not watching where I was removing the tool from the work and it banged on the rim.
Re: Catches? Why?
adrien
>For me a catch is the easiest way to dismount the potential bowl. It is always fascinating to watch the wood arcing towards the ceiling and the satisfying thump it makes when it hits wall and floor would be sorely missed, TD, if all catches were eliminated
Re: no catch issues here
Whit
>Hey folks, don't forget your ABCs. Anchor, Bevel, Cut. No catches.
JamieDonaldson
>I bet no turner would try to hold a big gouge between his legs more than once!!
>HAHAHAHA!!! I can just picture me doing that and my lovely wife popping in to do some laundry, seeing me with the big Kelton handle between my legs, rolling her eyes in disgust and uttering..."men...ugh...always with whats between your legs..I don't know how you live with those things".
HAHAHAHA!!
Russ Fairfield
>I remember seeing a photo of John Jordan turning the outside of a bowl by holding a bowl gouge with the end of the handle sticking in his belly button and his hands in the air. This was in the American Woodturner, and there was a lot of flack given the AAW about showing it.
Regardless of the safety issue, it did prove the point that we don't need a death-grip to control the tool.
Dick Hines
Dick Hines
>Jamie, that's a bad picture!
