Stump Removal
Stump Removal
Stump Removal
Joseph
>I went to a part of my property that was recently clearcut. There are several walnut and cherry stumps that I would like to remove. What is the easiest way to get them out of the ground. A friend of mine has a dozer, but I doubt that it can get to them.
Thanks,
Joseph
Re: Stump Removal
Re: Stump Removal *LINK*
Joaz Hill
>Dynamite!!!! You might lose some of the wood from the blast but you would probably end up with some usable pieces. That's the way we used to take care of 'em down on the farm.
Be careful.
http://www.maine-web.com/woodturning
Re: Stump Removal
Re: Stump Removal
Al Kapocius, Metro Greendale
>If you're not too partikular, drill a bunch of holes in the stumps and fill the holes with a high nitrogen content fertilizer. Should promote rotting, though it may take about four or more years.
There was a product that contained saltpeter (potassium nitrate salt) which would soak into the wood. Stump could then be burned out. Gasoline or kerosene would help, but adding kerosene (fuel oil) would make it equivalent to the dynamite mentioned above.
Al Kapocius
