PM3520A Shortfall
PM3520A Shortfall
PM3520A Shortfall
Roy Girolami
>I was making a plant stand out of some pine I had staved together into a tapered cylinder. I had cut the pieces to be 30" long. I got some end fillers on so I could mount it between centers, which on the PM3520A is 35", right? Apparently the measurement is without centers in place, because that 30" piece would not fit. I ended up having to stick the tailstock about halfway off the bed in order to mount the piece.
Not too happy, but not too surprised.
Roy Girolami
Apex, NC
Re: PM3520A Shortfall
Russ Fairfield
>A common problem with all lathes. The between centers dimension is measured WITHOUT the centers being in place. The actual dimension will be about 6" less than advertised.
Mike Rubes, Apex, NC
>Hi Roy,
Like you, I guess I am not too surprised, but I would have thought that the 35 in 3520A would mean 35 inches between centers. I wonder if all lathes are measured and marketed this way?
Where in Apex are you? I am just up 55 past 64.
Mike
No turning 'till I get a new belt in Apex, NC!!!
Not all...
TDaniel
>I just measured my Vicmarcs. the little VL100 is supposed to be a 10 x 15" lathe; with centers installed I can mount 15 1/2". The big VL300 is supposed to be 50" between center and with centers installed it would handle 54" ok, will actually handle the advertised 50" with the tailstock sitting fully on the bed. The higher priced lathes, I think, deliver more of what they advertise than the low priced ones.
TD
Roy Girolami
>Most ads for lathes I have seen indicate the length between centers. Cursory inspection of both Craft Supplies and Tool Crib catalogs give a betwen center distance of 34 1/2". This is not true. To mount a 30" long piece, the tail stock is hanging off the end of the bed by 1". This is not good for alignment, since the key for the ways is located at the very end of the tailstock, which is not near the bed in this situation.
Notice the catalogs say "between centers" which implies that the lathe is long enough to mount a piece that length and be safe to operate. I have to admit I am beginning to wonder if this lathe is what I thought it was going to be when I purchased it. When I use it, it is very satisfactory, but whenever I try to use it towards it capacity, it seems to bite me with its inadequacies. I guess you get what you pay for.
Mike, I am over in the west part of Apex, near Jordan Lake.
Roy Girolami
Apex, NC
