ebonizing
ebonizing
ebonizing
Joaz Hill
>Here is a pic of a small maple hollow form.
I have been experimenting with different ways of ebonizing. I tried disolving steel wool in vineger but it was a bit to spotty and seemed to take several applications.
Then I tried stove black and it works great. It has wax in it and buffs up really nice on the lathe. This is the same stuff that you get at the hardware store to restore your stove surface.
The top of this vessel IS ebony.
Fom the looks of this photo, the piece could use another coat.
Re: ebonizing
Re: ebonizing
Ric Erkes
>Joaz, looks good from here. Another solution is to mix black graphite powder with sanding sealer, courtesy of a Phil Brennion demo. I use the TLAR (that looks about right) ratio of mixing it. It has that slight blueish metallic look.
This piece was hollowed from the bottom, plugged, turned multi-axis, textured with a micro file and then the solution was applied because the wood itself wasn't very pretty. Finished with Polyurethane.
By the way Joaz, thanks for posting your inverted scraper. I'm going to try that as soon as I find a gouge I want to reshape. I assume you hold it handle high like other scrapers?
Ric
Re: ebonizing
Re: ebonizing
Joaz Hill
>He Ric, yes the shear scraper handle end should be held up as per normal scaper.
On the outside of bowls I have held the TIP almost vertical at the bottom of the bowl and bring it to horizontal as I work from the bottom to the top of the bowl. This is with the bowl chucked at the foot.
BTW your pic did not come through.
Question: How do you post more then one pic in a post???????
Re: ebonizing
Shear scraper in action for Ric
Joaz Hill
>Here is inside view of shear scraper in action.
Re: ebonizing
No picture?
Ric Erkes
>I'll send it separate to you. When I click on it, it's there.
Re: ebonizing
Re: ebonizing
Pascal Oudet
>Joaz, ebonizing with iron acetate (steel wool+vinegar) involves a chemical reaction which only works with tannic woods: chestnut, oak. works also on Locust (robinia pseudoacacia), cherry and probably a few others.
Ash, maple are not tannic wood, so this method is not applicable.
Unless you add tannin to the wood before ebonizing, by applying a strong tea solution (tea contains tannin)
Pascal
