Octagon tool handles
Bob L.
>I want to turn about 12 socket chisel handles with the grip portion being in an octagon shape. I would appreciate some advice as to how best to flatten each side so each side has the same length and width. Thanks
Bob L.
Re: Octagon tool handles
>Leave the lathe, off.
Tune up the band saw.
Tune the ripped octogone with a stationary belt sander.
You can the put between centers to cut end-tenons for the ferruls.
Done |;-}}
Good idea!
Dominic Greco in Richboro PA
>Not a bad idea! Using a jig like this, you guarantee uniformity between handles as well.
Dominic
>Bob
I'll rev up my brain when I get home. I used to know an easy way to set the rip fence to the exact setting to take the corners off a square piece and end up with 8 equal sides. Perhaps I'll remember when I stand at the saw.
I use a block plane or spoke shave mostly for short eight sided handles. It's faster than the table saw for onesies and twosies.
>Bob
Here's the table saw way to cut octagon. Cut the wood sqare. Set the blade to 45 degrees. Tilt the wood to 45 degrees and set it against the blade. With the saw off of course. Move the fence up until it touches the corner of the wood. Now set the wood flat and cut off all 4 corners.
It gets more complicated if you want a tapered octagon. You have to build a taper jig. That's why I do most of mine with a hand plane or spokeshave.
Re: That's Why
>I sugested to tune the handle with a belt sander. Cut the octogon and sand each face to the shape (tapered AND curved) desired.
'Course a spoke shave'll do it that much faster.
[d'anybody get the number on that neander's truck?]
