THE WOODRAT IS BACK!
Jet 1236/Vacuum chuck hookup
sroxberg
>Has anyone solved the problem of hooking up a Vacuum pump to a Jet 1236? I just bought the pump, and now need to connect it to my head stock.
Any previous experience or ideas would be greatly appreciated.
Re: Jet 1236/Vacuum chuck hookup
>I used the EZ Vacuum adapter that I bought from Packard for my 1236. It worked so well that I kept it when I sold the lathe. My Stubby has an internal vac set-up but if that develps a problem I will use the EZ unit.
It was simple then to hook the vacuum ,pump to the lath with a piece of air hose and a quick-connect fitting that sealed with no leaks and assembled in less than 60 sec.
Good Luck
Mark Mandell
-2=mail
sroxberg
>Thank you for the quick response. I just placed the order for the entire artisan vacuum chuck system without the pump.
I purchased two muffler/filters and an air gage with the pump. I now need some hose, connectors, and a bleeder valve. And I should be ready to turn. I've seen the muffler/filters installed on both the inbound and outbound sides of the pump is that a good plan?
Re: External
>Filter on the intake (with a replaceable/cleanable cartridge - absolute must to protect the pump (even though they say they have an internal filter). Out-flow noise filter on a Gast, Robinair, Thomas, etc. - seriously recommended, they are annoyingly loud without it. Bleed valve = 1/4" ball valve at the Borg. Vacuum gage (NOT an air gage) available from most any machine supply.
Mark
Where to buy filter?
Stuart Johnson
Where can this type of filter be purchased?
Re: Where to buy filter?
>I use a mini filter/regulator from Harbor Freight, Item No. 43242-0VGA @ $15 [$7 when on sale]. McMaster-Carr also sells straight filter units, not sure of prices, as does Reid Tool and Grainger.
Re: External
sroxberg
>Here is a picture of what I purchased for $7.99 a piece from Surplus Center. I intend to place one on the in and the out. In as a filter, out as a muffler. Is this correct?
They refer to it as a VACUUM/COMPRESSOR PUMP FILTER/MUFFLER ASSEMBLY
Re: 7.99?
>Appears to be a sintered bronze fitting in a bottle. Should do fine both ways.
