A55 Smoothing Plane
Vacuum Pump Question
sroxberg
>Does this Vacuum pump like like it has the correct specifications for use on a lathe chuck, and for use with veneering applications?
1/4 HP Rotary Compressor Vacuum Pump
� New GAST 0523. Direct drive oil-less rotary vane vacuum pump.
SPECIFICATIONS
� HP 1/4
� Voltage 220 AC
� Amps 1.5
� RPM 1725
� 4.5 CFM at 0 PSI
� 3.6 CFM at 10 PSI cont.
� PSI 15 int.
� 0.5 CFM at 26" Hg max.
� Ports 1/4" NPT
� Duty continuous
� Thermal protection on motor
� Size 5 5/8" x 13 1/4" x 6"
� Shpg. 31 lbs.
Any other additional information or sites that someone could point me to on setting up my first system would be appreciated.
Re: Vacuum Pump Question
That's the one
Dale Sherman, Pompey, NY
>The specs are the same as the ones in the turning catalogs. It'll work fine.
Dale
Mark Kauder, Phenix City, AL
>A Gast 523 is perfect.
Mark
Try Wlm Noble
Darryl
>Try William Noble He has all the info you will ever need..
http://snmp.labridge.com/~wnoble/forsale/vac-pumps/gast.htm
Re:You did notice that its 230 v, didn't you?
Al Crandall
>That puts off a lot of people. But if you have the room in your panel for it, sieze the opportunity. I saw that one going for a fair price, but I have enough already, and the 230 v. wouldn't make a very good outfit for traveling. Go for it.
Mac
>That looks like the one I just purchased from Surplus Center. Works like a charm for less than 1/3 the price of a 110 volt one, go for it......
Re: Alternative
>If you don't mind turning a wrench and spending about $40 for fittings that you'll need anyway, you can put one together like this for about $40 as the compressor-pumps are freee after they're taken out a/c and dehimidifier units by appliance guys. This setup pulls 28" of hg and 4 cfm at full flow. It's housed in a box under my lathe (the fan is for keeping the pumps from overheating and tripping their thermal overloads) and runs very quietly.
Mark
Re: Alternative 2
>Other view showing the linkup. One unit is capaciter start, and the rig runs on 115v.
sroxberg
>I had noticed that and though not great, it's doable in my shop. I'll just have to wire in a new outlet, and I have plenty of room in the panel. Happy I put in a 100 amp sub panel now.
Anyone hook this up with a Jet 1236?
sroxberg
>That's my source as well. Did you do any fancy vacuum tanks, or just hook it directly to the lathe?
Do you lube it with those Shiner Bocks? :)
Joel Hunnicutt
Re: Lubrication
>Ve puts de oil in de pumps for to kep dem smooth. Ve puts da Summer Ale in da wisitors for to kep dem smooth.
Vacuum pump
Greg Jensen
>I would recommend installing a vacuum gauge and vacuum relief valve in line between the pump and lathe. This will allow you to know what level of vacuum is applied to the work and to make very fine adjustments to the vacuum level. These items can be purchased from WW Grainger and a quite reasonable.
Greg Jensen
Re: How does the price compare to $12.88?
Al Crandall
>There is one on ebay, item #3817260824 , which ends in about an hour which is going for $12.88 as of right now. Is that in the neighborhood of your price? Seems like a fair price to me.
