A new toolmaker
A new toolmaker
A new toolmaker
Russ Fairfield
>For those who pefer to Buy American, and at a reasonable price, we have a new toolmaker available to us -
Bob Sweazey
Sumner, WA
(253) 862-9643
seattlebob@comcast.net
His first offering is a 1/2" (actual diameter) bowl gouge made from an M-42 Cobalt allooy HSS that has been heat-treated in a vacuum and quenched in Nitrogen.
The shape of the flute is similar to that of the Taypor Superflute bowl gouge, with a finish on the tool is similar to that of a Glaser gouge. The tool handle is wood with a nice shape (for me), and it is drilled and filled with lead shot for weight and balance.
It comes pre-ground with a couple options. One is a conventional profile with a moderate sweep that isn't much different from what a lot of the folks here are already using. It is also available with a "convex" bevel profile. The thing that amazed me was that it was razor sharp and ready to use out of the box.
My first impression was that it looked like a Glaser gouge with a wood handle. It has a similar balance a feel to it. But, I like the flute profile better that the Glaser, and the larger diameter wood handle is more comfortable to hold than the metal Glaser handle for any length of time.
I have been using this tool for about 10 days. The good news is that the Cobalt HSS alloy grinds to as sharp and edge as an M4, sharper than V11, or 2030 (my opinion), and it appears that that sharper edge is retained as long as the best of them.
No, I didn't get a free tool, and I don't expect any. Mine cost the same $84, including postage, as anyone else has to pay. I like this initial offering, and I want to see Dave prosper as a maker of turning tools so there will be more and different tools coming.
I hope there is a larger 5/8" bowl; gouge not far behind this one.
Re: A new toolmaker
Re: A new toolmaker
Mike Schwing from Maryland
>Thanks for the report Russ! I'll be looking forward to a 5/8" version. Please let us know when you find it is available.
Re: A new toolmaker
Re: A new toolmaker
Molly Winton
>Bob's a member of our Seattle club, and I had the opportunity to buy one of his gouges at our April meeting. I didn't use it until today. I normally turn with either my Glaser or Hamlets, but I agree with Russ, I prefer the flute of Bob's gouge. It was a complete joy to use. The extra weight in the handle provides a good feel, and it holds an edge fabulously. I also bought this with my hard earned cash, and will get a 5/8" if he comes out with it. The 1/2" is smaller than I'm used to, but I've got absolutely no complaints. Here's what I made with it today...
Re: A new toolmaker
Re: A new toolmaker
Larry Barnes
>Does Bob have a website??
Re: A new toolmaker
Re: A new toolmaker
Russ Fairfield
>Not that I know of.
Re: A new toolmaker
Re: A new toolmaker
Mark Kauder, Phenix City, AL
>I Emailed Bob this morning after seeing Russ's posting, and this is what I got back from Bob.
Though much of it is a repeat of what Russ posted, I found it informative, and though you might also.
Thank you for your interest in the Sweazey bowl gouge.
The descriptive flyer for the gouge is quoted here:
"Proudly made in the USA, The Sweazey 1/2 inch bowl gouge is produced from premium M42 cobalt high-speed steel. This steel was chosen because of its superior wear resistance and edge-holding qualities compared to the more common M2. The heat treating process is accomplished in a vacuum chamber (to prevent contamination) followed by quenching in nitrogen. The steel is then tempered at 1000� F in a nitrogen atmosphere to achieve a hardness of 66rc yielding a very hard (but not too hard) material. The result is an exceedingly durable edge able to retain its sharpness for a very long time.
Well-known Pacific Northwest Wood turner Dave Schweitzer provided valuable assistance in meeting several design objectives. Beam strength of the tool when extended well over the tool rest, the capacity to expel chips freely and the ability to work well with a wide variety of grinds were accomplished in this deep-fluted bowl gouge.
The unique handle is drilled 12 inches from the outboard end and filled with lead shot. This provides "heft" as well as vibration absorption to the tool.
The superior edge-holding steel, the advanced flute shape and the vibration absorbing handle all combine into a premium bowl gouge that should be a pleasure for any woodturner.
The tool is available handled for $84.00 or unhandled for $59.00 plus shipping and WA sales tax for Washington residents."
There are two grinds available. One is the conventional swept-back thumbnail grind. The other is a convex grind referred to as the "DS" grind for Dave Schweitzer who is a strong proponent of this style grind and contributed greatly to its design.
Two pictures are attached. The first shows the entire tool. The second shows the two grinds available.
I will be looking forward to hearing from you and thanks for your interest,
Bob Sweazey
21701 112th St. E.
Sumner, WA 98390
253-862-9643
Re: A new toolmaker
Thanks Mark
Joel Hunnicutt
>Thanks for the additional info. Good looking tool. I wonder though how would you maintain the convex grind?
