200+ woodworking book reviews
Rattle, rattle, rattle inside a Oneway lathe.
Russ Fairfield
>Yesterday, on the last day of a 3-day class, my Oneway lathe developed a rattle. All this time I was thinking that only a Nova lathe had problems with broken motor shafts. Not true.
Tomorrow I get to make a call to Oneway and test their reputation for excellent and fast service.
Re: Rattle, rattle, rattle inside a Oneway lathe.
Edward
>Please Note: Monday is a holiday, in Canada. There might not be anyone at Oneway - but give them a try anyway.
What kind of a rattle noise?
MountainMan
>Hey Russ-I had the same kind-a-sounds comming from the headstock of my brand new JET mini - (the manual belt change one) I retensioned the drive belt - sound went away - why? I duno!!
Regards
MountainMan
Belt Tensioning Lever?
John McAtee
>Russ, I had a rattle in mine that I traced to the belt tensioning lever that pulls out. I solved the problem by simply stuffing a piece of rubber between it and the sidewall and the lever so it wouldn't vibrate. Here's hoping this is all your rattle is.
Best regards,
John (Johnsturn.com)
Richard Allen
Richard Allen
>Hi Russ
Imagine my displeasure when I found that my new Oneway lathe rattled at particular speeds. Fairly large ranges of speeds. I read the manual and it said something about tension for the belt. When I tensioned the belt the rattle went away.
I like the idea of a lose belt, sometimes, because of the catch/slip nature of a lose belt. But that rattle drove me nuts. So instead of loosening the belt I just don't get catches any more (I call them aggressive cuts).
Your rattle may be something entirely different. Anyway here is the specific passage in the manual I was talking about:
"Lower the motor, and apply downward pressure (25-50 lbs). While still applying downward pressure, tighten the speed handle to lock the motor in place."
Good Luck
Richard
Russ Fairfield
>My rattle is definitely something different. It is a broken motor shaft.
The shaft is broken clear through about 1/4" inside of the motor pulley. Only the key was holding it together.
