Question for Mark Kauder
John F.
>Mark, when you installed that vega vs motor on your lathe, did you make the circuit changes outlined on rocky mountain woodturners site, and if so, how did it turn out?
John F.
John F.
John F.
Re: Question for Mark Kauder
Mark Kauder
>I did cut out the resistor (D-3?) as suggested - doing so makes it so that you do not have to turn the dial down to zero each time you start the lathe.
I did not change the curcuitry that effect the ramp up speed. I think that having a ramp up to full power/speed is a good safety factor.
I am still using the setup (today even) and love it.
Mark
John F.
>My concern was about the ramp up, the message I read was that the ramp up also eliminated a problem of it not responding quickly enough to added load and could cause stalling, does this seem to be an issue?
Mark Kauder, Phenix City, AL
>I have not had a single problem with any of that. I would not change a thing that I have now.
Mark
John F.
>Thank you very much for the input.
John F
