Small Red Oak Funnel
Richard Allen
Richard Allen
>Don't you just hate when this happens?
I used to try and "save" these. I found that I didn't learn much by "saveing", that the "saves" looked at best "crafty" and more often like a piece of junk. To top it all off I found I could make a bowl from scratch faster than doing the "save" and the bowl from scratch always looked better.
I have seen the "saves" others do and they almost always look a lot better than my "saves". So there must be something to the "save" process that I don't understand.
Thanks
Richard
Re: Small Red Oak Funnel
Tony Reynolds in Newark, Ohio
>Nice bowl Richard. You could turn a contrasting plug, glue it in and call it a design feature.
Tony
Glenn Hodges
>Richard, I saw a post somewhere from a guy in Australia that put clear epoxy in the hole, and put a leaf from the type of tree it came from in the epoxy. It looked pretty neat. Try it.
Nashville, Ga
Mike Schwing from Maryland
>Ring for under the burner on the stove? You could start a design craze, or at least a fire.
Peter Teubel
>If its dry, its worth saving. Here's what I do:
Dick Hines
Dick Hines
>I saw sone bowls at an art show where the guy put brass plate in the bottom. He had done a design on the brass, like swirls
Dinyar Chavda
>Peter:
That looks really neat. Can you describe what it is, and how you did it? Not that I will ever have any need for it! :-)
Dinyar
