Cutting Burl for turning?
George Van
>How do you cut this to prepare for turning? I do not have a bowl saver and it seems a waste to just hollow out one bowl.
Any ideas?
Thanks, George
George Van
Any ideas?
Thanks, George
Re: Cutting Burl for turning?
Barbara Gill, Remlik Virginia
>Without a bowl saver you would probably get the most use if you cut into slabs for platters. You could always sell enough to help pay for a bowl saving rig.
Richard Allen
>Hi George
If you thing it's a shame visit a woodturner with a coring system.
It is wood like this burl that can easily pay for a coring system. How much would the two bowls you could core out of this be worth? Or how much would a hunk of wood with that character and size be worth to you?
Still the best way to go is to visit a friend and offer the friend the larger core. You get the big bowl and the small bowl and your friend gets a nice bowl. Sounds like you are both winners. You also get a chance to see how a coring system works.
Good luck
Richard
George Van
>Thanks Barbara and Richard,
I have three of these in the shop and more to come from other trees on the property that I marked for removal. One is about 4 �� in diameter at the base of a maple. I just roughed the exterior of a nice 17� yellow birch bowl plus have two more blanks like that one ready, I am hesitant to turn the cores into shavings. Maybe I will look into a bowl saver. I think if I do a search I will find a lot of info. I believe Bill Grumbine just had something recently. I also watched Steve Russell use one at a demo in February.
George
Richard Allen
>Hi George
If you want a no-brainer system with little of no learning cureve the Oneway system is it.
The learning curve is higher on the hand held systems but the price is a lot less.
If you have a club near then you could likely find member who have different systems. Perhaps you could try out some of the different systems to help you evaluate a system of your own.
Richard
George Van
>Thanks Richard,
I will be watching a Oneway this afternoon.
George
