TDaniel, question about mulberry.
jim moy
>i saw your post about anchorseal and mulberry. you said that it would still crack. is there a way to stop or minimize most of the cracks?
i've been turning alot of mulberry and most of mine are cracked or have small checks. is that the nature of this wood? thanks in advance.
Re: TDaniel, question about mulberry.
TDaniel
>Jim, when wood cracks while drying it is, as Russ says, the outside drying and shrinking while the inside is still full of water and not yet shrinking. The wood basically looks like a wet baseball whose outside cover shrinks on drying and since the inside does not shrink the leather outer cover rips. Some wood is more difficult than others to dry but all can be dried without cracking; you just have to find the right combination. Mulberry isn't easy but it can be dried.......just slow it down a lot for the first 2 weeks. Try Anchorseal and then put it in a corrugated box and fold the flaps but do not tape closed.
TD
Barbara Gill, Remlik Virginia
>Have you tried boiling the rough bowls?
TDaniel
>Barb, I have enough to do with out boiling.:) If I have to boil it I won't turn it generally. Now if I thought a Mulberry bowl would sell for $400 it would already be on the burner. Mulberry is ok but not fantastic so it is not on my list of desirable turning woods.
TD
thanks TD!! NM
jim moy
>NM
RevDoug
>Barbara, you read my mind. I believe that a mulberry bowl finished turned and then boiled would warp a bit, but shouldn't warp.
>Actually I was asking Jim; I should have been more clear. I didn't think you did any boiling.
Jim, Have You Tried Boiling?
Re: Jim, Have You Tried Boiling?
jim moy
>hi barb,
no, i haven't tried boiling yet. i actually don't have anything large enough to boil the peices that i've turned. thanks for the help.
Mac
>Actually Barbara, I've seen Terry boil a couple times.....
hey-hey
TDaniel
