THE WOODRAT IS BACK!
Textured Cherry Bowl
Dominic Greco in Richboro PA
>Hi Everyone,
Below are some pictures of a cherry bowl I just finished last night. As you can see, this bowl features a 1/2" wide textured band, bordered by (2) burned lines. This was my first real attempt at texturing, and I found the technique took some getting used to. I found it to be a lot like using a chatter tool. It all depends on the way that you have the tool address the bowl, the speed the bowl is turning, the angle of the tool, and the pressure you exert. I used my shop built texturing tool on this bowl, and I was very pleased with the results. After I finished with the texturing, I used my spear point scraper to cut (2) shallow grooves on the borders of the textured area. I was going to leave them as is, but decided to "set off" the textured band by burning the lines in with a guitar string.
Side view of textured Cherry Bowl
Top view of textured Cherry Bowl
Bottom view of textured Cherry Bowl
This bowl represents another small first for me. When dealing with problematic end grain (end grain that refuses to cut smoothly no matter what) I normally turn to wet sanding with a 50/50 mix of varnish and mineral spirits. This time, I wiped on this mix and allowed it to dry over night (basically allowing it to act as a sanding sealer). The next night, I power sanded from 100 to 220 grit, then used my passive sander all the way up to 600 grit. I then applied the texturing, and then progressed all the way to 2000 grit.
Bowl Specs:
Outer dia.: 9 1/4"
Height: 2 3/4"
Wall wall thickness: 1/4"
Base dia.: 3 1/4"
Sanding Method: Seal Coat of 50% Mineral spirits/50% varnish and then dry sanded to 2000 Grit.
Finish: Watco's Danish Oil
Final: Buffed with Beall System
Thanks for viewing.
See ya around,
My ugly mug
Dominic
Re: Textured Cherry Bowl
George Van
>Hi Dominic,
Always glad to see your posts. I have a note to try making your texturing tool. I just have to catch up on all my rough turning before I loose too many blanks.
I like your bowl with or without the texture. I do like the way the burned line and texturing draws my eyes to the rim.
George
Bill Grumbine, Kutztown PA
>Hi Dominic
Very nice! I might have to think about some texturing. It beats the heck out of sanding, eh?
Address the bowl. I laughed out loud when I first read this. My first and instant thought was of Ralph Cramden and Ed Norton, where Norton is told by Ralph to address the ball (golfing). He steps up to the ball and says, "Hellooo, ball!"
Hellooo, bowl!
Bill
Re: Textured Cherry Bowl *LINK*
Sean Troy
>Nice shape. The texturing inside the burnt lines really sets it off. I,m another one who needs to make the time to get the texturing tool to work for me. It adds a lot. Great pic. Best of luck, Sean
http://www.azwoodturners.org
Bernie
>Dominic very nice work. When you finish your bowls do you let the oil finish sit a couple
day before you wax/buff. Or is it done immediatly
Thanks, Bernie
Mark Kauder, Phenix City, AL
>Two Thumbs Up from Me, buddy.
Mark
Tony Reynolds in Newark, Ohio
>Beautiful work Dom. The burned lines and texturing is well placed and really sets this piece off.
Tony
"To the Moon Alice!"
Dominic Greco in Sunny Richboro PA
>Thanks for the compliments Bill!
At least I didn't have to play "Swanee River" every time before I started turning! :>)
The funny thing about the texturing is that you need a freshly sanded surface to start with. Here you go and spend all that time making the bowl all nice and smooth. And then you mess it up all in the name of "art" :>)
See ya around,
Dominic
Mike Rubes
>Hi Dominic,
Nice looking bowl. I like the texturing, it gives the bowl just enough of that something "extra".
All these great bowls are killing me! I am just about done with my dad's table, so I hope to actually set the mini back up and start turning some stuff this weekend.
Thanks for the pic,
Mike
Going through withdrawal in Apex, NC!!!
Jennifer@Indy.USA
>Nice One Dom! I like it. Wish I had the time to fiddle with making one. That cutter would be something to buy and tuck away for a rainy day tooling project.
Jen
Dave Peebles Lyons, Ohio!
>Hi Dom,
That is a beauty!!
I have a couple done in a similar way. And you are right, it take some playing around to get what you want. I love the effect on this one.
On another topic, I just had to restore the top on my Grizzly Joiner.(Surface Rust) I saved your link about how you did your restoration. Thanks, It worked out great!!
Best,
Dave
Thanks Dave!
>I appreciate the compliments about the bowl and the article.
Dominic
Thanks to all for the compliments!
