PM3520A Electrical Question?
Jim Smith
>Is a 220v, 30 amp circuit breaker and #10 wire correct for wiring this machine? (single phase) Thanks
Re: PM3520A Electrical Question?
MP Wall
>Matches what I have for it and my bandsaw. So far no problems. MP Wall
Bill Howatt
>Given it's a 2hp motor there is more than enough capacity. My 2HP electronic variable-speed General only requires a 15A 240V service.
Bill
Bill Hale / The Wood Spinner
>3 HP 20 amp with # 12 wire is adequate unless the wire run is over 100 ft. Over 100 ft I would go to the # 10 to preclude voltage loss.
Good turning and be safe
Bill
Dick Hines
Dick Hines
>Don't run #10 if you don't have to. It's a pain in the butt. Your PM will run off 15 amp and #12 wire. I used #10 because I had access to it any by the time I finished I was about ready to shoot myself.
Jim Smith
>Thanks for the input. I already have about 30 ft. of #10 so I think I'll just use it instead of buying the #12. Thanks again, Jim
Bruce McElhaney Spring Lake, MI
>IMO, #10 wire is overkill for a PM3520. I agree that #10 wire is pretty stiff and a pain to work with unless it's all open or straight runs. You could easly run #14 with a 15 amp breaker and be within specs. I already a #12 220 run with a 20 amp breaker. So that's what I used.
Bill Hunt
>I just did this yesterday. My electric supply store said that since the wire was 12AWG all I needed was a 20 amp double pole breaker and the regular 220 outlet and plug.
Since I had spent as much as the 3520 cost I did go ahead and buy the higher priced plug. Man does this thing HUMMMM!!
Whoa!
Phil Murray
>That 2HP motor says 15.3 amps, so #14@15amps is too light, IMHO. Totally agree with #12@20 amps, but make sure your two pole breaker is double wide with a contact for each buss bar (my first didn't, so extra trip!) You're gonna love that baby in spite of the color.
Phil
Re: Its 230v. Less than 8 amps per wire.
Al Crandall
Re: 15.3 amps?
>That sounds more like a 110v motor. My new PM 3520a came with the standard 2hp, 1720 RPM motor rated at 6.2 amps @220V. Obviously it's well within #14 wire, 15 amp 220 breaker capacity.
Re: Whoa!
Rick R, So Cal
>Some back-of-an-envelope calculations, as an old engineering prof used to call these quick estimates:
2HPx ~750W/HP = 1500W
1500W/220V = ~7A
Note that the motor is 3 phase, so its nameplate current rating will be lower than 7A, but that doesn't enter into the equation. The power that goes into the VFD equals the power out of the motor, minus losses.
What all this means for me is that the 15A rated power cord and plug that I'm using are ok. Also the 20A service that it's plugged into is more than adequate.
Rick
Humble apologies
Phil Murray
>Just shows what happens when ya know a little, but not enough.
Sorry for the bad info. Mine is grossly overwired!
Phil
