Log hoist?
Phil Murray
>Since tearing up my back 10 days ago, I've been trying to figure out easier ways to get "free" logs into my truck bed (are they still free if it costs $500 for chiropractic work?). All ideas for cheap solutions welcome!
Phil
Log hoist?
Phil Murray
Phil
Re: Log hoist?
>Phil
There was a tip in American Woodturner on building a lever type log hoist. I didn't keep the photo on my computer but I can copy the tip and send it to you if you'll send me your mailing address.
I can describe it. It was basically a ladder about or 6 feet long with a board placed near the middle. The log is rolled on the ladder and stops at this board. The board is placed so it's exactly the height of your truck bed and large enough to keep the log in place while you lift the other end.
It's kind of like dumping a wheelbarrow into your truck. It doesn't remove all the lifting weight but reduces it tremendously.
Re: Log hoist?- *LINK*
scott stefanoski in Beautiful Baltimore
>what about something like an engine hoist. you could set it in the ground, hoist the log into the bed, and then place the hoist back into the truck.
Engine hoist
Re: Log hoist?
Duane
>I have the same problem.Bad back.So I got a truck hoist from Harber Freight and 1/2" steel plate about 24"X24" all fo under $100.Bolted it all to the back left corner of the bed.I have lifted logs 30"X40" with it with out any problems.I hope this helos.
Re: Log hoist?
Bob Tabor
>Look in Harbor Freight they have a small fold up hoist that mounts in the rear corner of your pickup bed. I think it will lift about 500 lbs. it folds up out of the way when not in use.
Re: Log hoist?
bill crommett in Seneca
>I have the harbor freight hoist on my truck, but I use a length of steel tubing to extend the reach so I can lift a log of great diameter high enough with a chain attachemed to allow it to swing into the truck bed easily.
Re: Log hoist?
Phil Joines Krum, Texas
>This is a log trailer built by John Tolly. To use it back the trailer over the log. Lift it with the hoist and chain the VW front end under it. Move the trailer to the fromt end and again hoist and secure it. Drive away.
Re: Log hoist?
Phil Murray
>Thanks all for the great suggestions. Looks to me as tho the H.F. bed mount at just under $150 is the quickest sure-fire solution.
Really appreciate your help, once again.
P.S. Flash
Phil Murray
>Just got a new Sportsman Guide catalog that has a 1000# capacity bed mount hoist for under $70.
Re: Is it a hoist with a cable or a pivoting crane
Al Crandall
>You have piqued my interest. I have never heard of the catalog you mentioned, so I doubt I'll be able to find out anything unless they have an on-line catalog, or you give me a lot more info. Willing to help me out, here?
Al
Phil Murray
>Pivoting crane type. www.sportsmansguide.com
Post (or email me a correct address and I'll send details. Their phone # 1-800-888-3006.
Item #DX4X-78203
