shop built vac chuck
John F.
>I'm looking for plans for a shop built vac chuck, I found the one in the articles, but it seems to assume my spindle is hollow, doesnt work for me, how would I go about setting this up?
Re: shop built vac chuck
Re: Give a hail to Bill Grumbine on this board.
Al Crandall
>Solid spindles present problems which are not easily overcome with marginally equipped home shops, as they need a slip ring capable of holding vacuum. Bill is THE man for solid spindles.
Or......
TDaniel
>the Vacuum plate made by Vicmarc which utilizes a shop-vac for the vacuum is a reasonable alternative. I use mine with a Fein shop-vac (which has bypass cooling) and it works quite well. If you have a Vicmarc chuck this plate can be gripped in the dovetail jaws; if not, you can order a bushing and thread it directly onto your spindle. It is cheap, it works, and it can be installed or removed in seconds.
TD
Re: Or......
John F.
>Do you have a link to this item?
Here *LINK*
Jeff Gerardot, Indianapolis IN
>Search for item #991-4400
That one's for 1x8tpi spindles, there are other sizes available.
http://www.woodturnerscatalog.com
Re: Or......
Bill Howatt
>Can you use it with a vacuum pump instead of a shop-vac?
Thanks,
Bill
no
TDaniel
