PM 3520A Chuck Query
john c. (virginia)
>I'm beginning my search for a chuck. Does anyone have a recommendation for a chuck that works well on the PM 3520A? Thanks in advance. John
john c. (virginia)
Re: PM 3520A Chuck Query
>I'm real happy with the Vicmarc 120 but if you are going to turn work that is as big as the 3520 will go I would go for the next size up. The big oneway would also be a good choice.
Joel Hunnicutt
>You'll get allot of votes for oneway and vicmarc, you won't go wrong with either. I've had the big vicmarc for about 2 months and it's a heck of a chuck. I'm just finishing hollowing a piece 14 inches off the headstock and the chuck is holding solid as a rock.
David Galloway
>We are fortunate to have so many quality chucks to choose from. I have the Oneway Stronghold and find it really is sweet. One key difference is that Oneway needs a straight tenon or recess, while the Vicmark uses a dovetail. Lot of my friends swear by the dovetail. Luckily, Oneway is now making a set of jaws that are dovetail. Pays yo money, takes yo chances. Either way, a win.
Sourcing?
john c. (virginia)
>Thanks for the quick responses, I'll look into both. If it's not too much to ask, is there a favored supplier for either/both? John
Re: Sourcing?
David Galloway
>I think they all run about the same prices and the service has been good on all suppliers. Some might note the "Evil Empire" but you did not hear that from me!
Bruce McElhaney Spring Lake, MI
>John, I did a lot of research to find a chuck for my new Powermatic. There are a lot of subtle differences, and no perfect choice. A lot of it depends on the type of work you plan on doing. I had it narrowed down between the Axminster and Oneway, and finally went with Oneway stronghold chuck.
Re: PM 3520A Chuck Query *LINK*
Russ Fairfield
>The linked article will not tell you which chuck to buy, but it might make your choice an easier one.
The only thing that might limit your selection is that some of the smaller chucks may not have an adapter available for the Powermatic spindle.
Which Chuck??
Dick Hines
>You got a lot of info. but no one said anything about the Super Nova. I know some don't loke them because of the key. I have 2. One is the Super Nova with the dove tail jaws and the other is Super Nova with the power grip jaws. I have had the dove tail chuck for over 3 years and work it hard and other than having to clean the gears, you have to do that with most all chucks, I like them.
Than being said in the near future I am going to get a Axminstewr 4" precision chuck with the 16" button jaws. It's cheaper than a vacuum chuck.
Good luck.
Re: Sourcing?
>Check with Terry Daniels on the Vicmarc chuck. I do't know for sure if he's still carrying them by since he reads this group I'm sure he'll chime in.
MP Wall
>I put new spindle adapters in my vic 100's and they are just fine. Note though, I am not turning to capacity just yet. I think the Vic is a great chuck and if I need to upsize will go with the bigger vic.
MP Wall
John Cahall
>I've got a Oneway Stronghold and 2 Talons. They are great. The one thing someone told me when I started my search was that the Oneways tighten clockwise and that others turn "the wrong way" That was good advice as I have used others and get easily confused. Whatever you get when you buy a 2nd chuck (and you will) make sure they both tighten the same way.
Thanks very much for the replies
john c. (virginia)
>I'll look into both and see what will work best. Turn safely. John
Bill Hale / The Wood Spinner
>I preffer the Vic only because it uses an allen type wrench for use.
Good turning and be safe
Bill
>As I understand it, Austrailian made chucks tighten backwards from English or Canadian made chucks. I'm most comfortable with the old,
"righty tighty, Lefty loosy" direction.
Russ Fairfield
>Vicmark is now making their new chucks with a RH Clockwise twist to tighten.
