Willow bowl (pics)
Willow bowl (pics)
Willow bowl (pics)
Dominic Greco in Richboro PA
>Hi Everyone,
Below are some pictures of a Willow bowl I just finished last night. Mike Rubes gave me this hunk of Willow last year at Bill Grumbine's BBQ. I immediately rough turned it, and allowed it to air dry until last week.
Bottom view of Willow bowl
Plan view of Willow bowl
Elevation view of Willow bowl
At the time I rough turned the willow blank, I was thinking more along the lines of utilitarian bowls. Hence the rather uncomplicated nature of the profile, as well as the greater than average (for me at least) wall thickness. While final turning, I decided to add a rolled bead at the rim to break up the rather stark profile. But what I also didn't want to do is distract from the unique appearance of the wood. IMHO, the many bore holes give this an almost "artsy" feel.
If you've never turned willow before, you're in for a surprise. Willow is much like Silver Maple in that it will "fuzz" unless cut with a very sharp tool. I started out trying to fill the worm holes with Turquoise Inlace. But due to the small size of the holes, and my inexperience in using this substance, I ended up turning all of it away. After that failed, I decided that the holes were better left "as is".
Bowl Specs:
Outer dia.: 11 1/4"
Height: 4"
Wall wall thickness: 1/2"
Base dia.: 3 1/4"
Sanding Method: Wet Sanding to
2000 Grit.
Finish: Watco's Danish Oil
Final: Buffed with Beall System
Thanks for viewing.
See ya around,
My ugly mug
Dominic
Re: Willow bowl (pics)
Mike Schwing from Maryland
>GREAT work Dominic and that bottom treatment is as nice as I've ever seen. Extremely professional looking!
>Good job Dominic. I got some will this winter and haven't had time to turn it yet. Hope it hasn't gone bad.
Duane
>Nice bottom Dominic.Never thouhgt I would say that to another man. Good job
Nice one Dom
>Hey Dom, Nice bowl there. I like the way you detailed the bottom of it. Looks great!
Tommy
Re: Nice one Dom
Joe Herrmann
>Dom:
Is this "weeping willow" or the black willow that is plentiful in the South? I used to buy a lot of Willow boards for student projects when I was teaching and liked the way it looked and worked. I've never seen it in chunks large enough to turn without laminating it--It looks great. Very nice job!
No idea!
>Joe,
You wrote:
"Is this "weeping willow" or the black willow that is plentiful in the South? I used to buy a lot of Willow boards for student projects when I was teaching and liked the way it looked and worked. I've never seen it in chunks large enough to turn without laminating it--It looks great. Very nice job!"
Thanks for the compliments!
Taking a wild guess, I'd assume it to be the more plentiful "Black Willow". You'd be better off asking Mike Rubes that question. He's the one that gave me the willow in the first place! Hopefully, he'll chime in on this.
See ya around,
Dominic
Bill Grumbine, Kutztown PA
>Very nice Dominic! I remember slicing that log in half. How about those thick bowls? IT looks really good.
Bill
Keith Tompkins
Keith Tompkins
>HI Dom, I like it!
Hi Bill
Dominic Greco in Sunny Richboro PA
>Bill,
Thanks for the compliments. The wall thickness is about 1/2".
See ya around,
Dominic
Thanks for the compliments everyone!
Bill Hale / The Wood Spinner
>Dom
Looks great, love the bottom.
You said you tried Inlace and not good. I have started using the black CA on that type of small holes and it is great. Fills the hole and adds impact to the appearance.
Good turning and be safe
Bill
Bruce McElhaney Spring Lake, MI
>Beautiful bowl! A well known woodturner one told me that Willow isn't any good for turning. You're proved him wrong. . .
Re: Willow bowl (pics) *LINK*
Eduardo Sarmiento Hall
>nice bowl I have turn a lot of willow and is just luck to get a goog piece in my psge I have some willow pieces and burls too ED
http://www.esarmiento.250x.com
Mike Rubes
>Hi Dominic,
Great looking bowl! I'll echo other's comments and say the bottom treatment is great. I've roughed out the other half of that log, but it's still sitting on the shelf. I hope mine turns out that good :)
Thanks for the pics,
Mike
Sand table almost done, lathe in sight in Apex, NC!!!
