PM 3520 Delivered - Long
George Van
>Last week the phone rang and it was UP Delivery with a 776# package. Load limits are still on so I had him deliver to SS Sports in Mercer and met him there. They took their forklift and put it in the back of my truck. I brought it home, took off, and place it in the shop with the bobcat. I had it wired and cleaned by evening and finished roughing a bowl.
At first it seemed like I had never turned before, not that I�m an experienced turner. I took my time and adjusted the rest, my PM 45 rest was so high I never had to worry, this one the rest rests 1� lower than center. Then I adjusted the speed to 200 rpm and started to rough, realizing I did not have to re-trim the blank to get it to fit above the ways. I noticed immediately the ability to change the angle of the gouge and see the results, good or bad, without problems. It was much easier than at 600rpm, and I believe safer for a beginner like me. I was able to use the tools in many angles I was afraid to try for fear of bad catches or dismounting the piece. I believe I will be able to learn a lot faster with the variable speed.
I did notice that there is not the safety of a slipping belt that the PM 45 has. For that reason I will have to stay sharp, but I think the initial starting speeds will be a big help. I did notice that it helps to have the speed higher as the blank balances.
Sliding the head forward and removing the tailstock after the blank was reversed to the chuck was also nice and very easy on my back. I was able to have full movement for the tool handle which was a treat for me. I could easily come across the blank with the handle lowered and start the final cut down the inside of the bowl with a �� curl and come across the bottom.
I have been roughing out a lot of blanks I had stored before they start to split.
I think the 3520 will allow me to learn faster and turn safer and more comfortably.
Thanks to all who recommended the lathe, it was good advice!
George
Re: PM 3520 Delivered - Long
Bruce McElhaney Spring Lake, MI
>George, I have a two month old PM 3520a and love it. Looks like you've been pretty busy with yours. BTW, You should be able to adjust the belts to slip a bit on your 3520.
>I love my 3520 as well and he's right you can adjust the belt to make it slip if you want.
George...
W.C. Turner
>Just loosen that belt a little, then relax!
MP Wall
>Now it looks like you need to get a better shaving removal system, since you can produce them much faster with the 3520. I love mine, and they are correct on adjusting the belt tension to allow some slippage.
MP Wall
Love the color
David Galloway
>As a PM fan, I just love the golden color aka birdpoo. You are going to have a blast on that lathe.
David Galloway
George Van
>Thanks guys, I will adjust the belt in the morning.
I sure do enjoy it, now I can think of other things I need before I start to finish the roughed bowls starting with dust protection.
George
