Glue Glass to Wood?
Glue Glass to Wood?
Glue Glass to Wood?
Robert Simmons
>I've finally turned a stem for one of those wine glass tops that I got a Woodcraft a year or so ago. Now I've got to attach the glass to the base. Hhhmmmm. I've been thinking of using a silicone glue of some sort, but I'm open for suggestions of anyone has experience with these things. I'll post a pic when it's done.
Thanks,
Robert
Re: Glue Glass to Wood?
>Robert
I've been using clear silicone caulk for my mirrors for years and have made a few goblets and used it for gluing them to the wood. Works great.
Richard Allen
E600
Richard Allen
>Hi Robert
E6000 Multi-Purpose Adhesive is an execlent product for the application of glueing glass to wood.
Thanks
Richard
Re: E600
JamieDonaldson
>John- I assume from your response that you've had no trouble with the adhesive melting the silver backing on the mirrors?
Re: E600
>Jamie
Not a bit. I first purchased some mirror adhesive. it was about $7 per small tube. It smelled, felt and tasted (OK I lied about the tasting) just like clear silicone caulking which was $5 for a large tube. I tried it and have been using it for about 7 years.
I made the mistake of trying liquid Nails. Mirrors started falling out. It actually stuck to the glass but came off the wood. fortunately it happened really quickly and all of the pieces were in my local gallery. Needless to say I went back to the silicone.
E600 is a good adhesive but I haven't used it for gluing glass to wood so I can't comment on that. I've used it to glue metal to wood, leather to wood and plastic to wood with good success.
Re: E600
JamieDonaldson
>I've been using a sealant/cement called GOOP but haven't really tested it. Seems to attach things better than silicone sealer and is thinner for tight joints. Anyone have experience with this stuff?
RonZ
>Agreed. Silicone works best with the shifting of the wood. I use it also to attach ceramics or marble tiles to cheese plates.
RevDoug
>E600 or Goop are both great products and should give no problems. I'm not sure about the original use for the E600, but Goop was designed to be used on the soles of shoes, to repair the rubber soles of athletic shoes when the wearer wore a hole in them. It is tough stuff and wears like iron. We've used it in our shop for loads of applications and have never had it fail.
>I've used what's called Shoe Goo. It is great for gluing the foam sanding pads back together when they come apart.
RevDoug
>basically the same stuff John.
Thanks
Robert Simmons, Atlanta
>I've used Goop on shoes before and my wife has a big tube of E6000 in her jewelry making kit, so I should be good to go on adhesives. Durn!, no excuse to hit the WW stores again (yet).
Thanks much,
Robert
