Swept-back fingernail grind
Judith Burnett
>I'm trying to get a swept-back fingernail grind on my 1/4" Henry Taylor micro turning tool. Can anyone give me the angles to create this.
I have a Wolverine grinding and sharpening jig, with the fingernail/side grindig jig attachments.
Re: Swept-back fingernail grind
RevDoug
>If you have it set up for other size gouges, then you simply insert the 1/4" in the same distance and grind as you would any other tool.
Don Porter
>Here is the link to Oneway's instructions.See "using the vari-grind to create a side grind" on page two..Good Luck, Don Porter
http://www.oneway.on.ca/Oneway/pdf/vari-grind.pdf
