1st bowl
1st bowl
1st bowl
floyd knapp
>I'm going to try and post some pictures of some of my turnings. This bowl is a replica of an antique candy bowl that we have. It is cherry and is the first bowl that I made after getting my lathe in 1990.It is laminated of rings and the wall thickness is 3/16".It is 5" d x 61/2" h. I'm not sure of the finish but I suspect it is lacquer.
Floyd
Re: 1st bowl
Re: 1st bowl
floyd knapp
>Sorry guys something wrong.I set it up and punched send and nothing happened.When I returned to this message board there were two messages sent but no picture.Can someone help me out? Many thanks.
Floyd
Re: 1st bowl
Re: 1st bowl
john dillbeck
>I suspect you need to resize it to 40 kb
Re: 1st bowl
Re: 1st bowl *LINK*
Lloyd Johnson
>Floyd,
There are many shareware programs that let you change the resolution of photos. One that I like is Irfanview. You can download it for free from the link below.
Once you install it, open your file and then go to Image > Resize/Resample. A reasonable size for photos for newsgroups is 640 x 480 or less at 72 dots per inch. Save your file with a new name and you'll be amazed at the difference in size before and after Irfanview.
Irfanview
Re: 1st bowl
Re: 1st bowl
floyd knapp
>Thanks a lot Lloyd for your response.I shall give it a try.
Floyd
