Sycamore Burl
Sycamore Burl
Sycamore Burl
Bernie
>Pretty new to this turning but I have a chance to get a pretty large sycamore burl 24"wide by 12'deep. Anyone have experience with it good or bad? And best way to dry it
Re: Sycamore Burl
Re: Sycamore Burl
Tony Reynolds in Newark, Ohio
>Hi Bernie,
Sycamore is beautiful wood. I don't think you want to dry it. You want to seal it to keep it from drying too fast and checking. You can use a product call Anchorseal a waxy paint like substance or dip it in hot paraffin and let it set up. If none of this is available painting the exposed cuts with several coats of paint will help seal it. Then store in a cool place until ready to turn.
Tony
Re: Sycamore Burl
Brad Vietje
Re: Sycamore Burl
Brad Vietje
>Bernie,
If this burl is sound, you'll probably want to find someone who can advise you in terms of how to cut it into usable parts, and perhaps core it into a number of bowl rough-outs. Most people will tell you you DON'T want to dry it, at least until you have rough-turned something out of it. For now, your best bet is to keep it from drying.
If you are new to dissecting burls, I can give two pieces of advice: 1. There's no one correct way to do it, and 2. No two burls seem to be the same on the inside. I'd seek out someone in a local turning group who has a reputation for turning burls and natural-edge bowls, and see if they will work with you.
Good luck -- nice find !
Safe Spinning,
Brad Vietje
Thetford, VT
Re: Sycamore Burl
Re: Sycamore Burl
Bernie
>Thanks for all the help and advise....
