Haiku
Richard Allen
>Spinning square edge bowl
Will promises beauty with risk
I hurt my finger
Haiku
Richard Allen
I hurt my finger
Re: Haiku
Dinyar Chavda
>Richard:
I think that should be:
I got booboo on my finger
:-) and sympathies!
Dinyar
Re: Haiku
RevDoug
>The trick is to keep your finger out of the path of the spinning corners.
Glad it wasn't worse. Let's be careful out there. And, send a pic of the square bowl.
Re: Haiku
Russ Fairfield
>A few things you might consider to make those spinning corners more visible and safer to work around....
Locate a laser pointer overhead so it is pointed downward at the tips of wings. This gives a permanent reference to where they are. When the beam is seen on your finger, it's too late.
Shine a bright incandenscent light at the area where you are cutting with the tool. This illuminates the ghost image so it is easier to see what you are doing. Incandescent because there is no flutter as there would be from a flourescent bulb. It also helps to dim the background light.
Move the On/Off switch for the lathe so you never have to cross the path of the wood to reach it. This becomes a real safety issue when turning large square pieces that are near the lathe swing cpaacity.
Re: Haiku
Ruth
>Pretty finger! You just made a memory and have a story to tell your grandchildren,"....and this scar..."!
Guess you know what you did wrong and what not to do again. : )
Ruth
