Pen Starter Kit?
Pen Starter Kit?
Pen Starter Kit?
Doug Whitson in Phoenix AZ.
>Hi all, I'm from the flat side so my experience with the round stuff is limited. I recieved a cheapo HF lathe for Christmas. I'm interested in turning pens. I thought I would get a starter pen set from Rockler or Woodcraft or ??? I'd like to get a kit that is pretty inclusive as I have nada in the pen department. I have skews and a parting tool and can get another turning tool if needed. Hence my question. Which one to get? Where? I'll take any all advice.
(ps) I did a search of the archives with no luck.
TIA-Doug
Re: Pen Starter Kit?
Bill Hale / The Wood Spinner
>Dough
I live in Casa Grande and shop Phoenix. As for turning stuff I find it lacking. Below I have listed two phone numbers to get catalogs. There are more but these have almost anything you might want, for now anyway.
The Woodturners Catalog 1 800 551 8876
Packard Woodworks 1 800 683 8876
Both of these ar good folks and helpfull.
This is a great site and almost all here will give you a quarter answer for a nickle question.
Welcome to turning, your wife is now a turning widow, as it is totally adictive.
Good turning and be safe
Bill
Re: Pen Starter Kit? *LINK*
Sean Troy
>Hi, You can try Bill Baumbeck at Arizona Silhouette. He can help you. I don't think he's to far from you.I'll post his link. You could also come to the Arizona Woodturners meetings and find a lot of pen turners. www.azwoodturners.org Good Luck, Sean
http://www.arizonasilhouette.com
Matt Bery in MI
>Here are thier online links
Packards http://www.packardwoodworks.com/
Wood turners catalog http://www.craftusa.com/
These are just in case you'd perfer visiting them online instead of calling ;)
One more source... *LINK*
Joe Pack
>Take a look at Berea Hardwoods. Check their web site for their starter kits, then call them and talk to Larry. Jim is great, and is the owner, but Larry is the guy who will cut to the chase and, if you tell him what you want to do, will set you up perfectly. Shipping is, or at least, was last time, a flat $3.50 per order.
By the way, Berea is the supplier for most of Woodcraft's stuff, along with supplying for a few other "biggies," too.
Note that their kits do not use a "universal" mandrel. Instead, they use an "A" or 7mm and a "B" or 8mm mandrel for larger pens. These mandrels fit into morse taper holders, so be sure you are getting both the mandrel and the morse taper(s) to fit the mandrel size and your lathe.
http://www.bereahardwoods.com
Re: One more source...
Joe Pack
>p.s. I do NOT recommend the American kit as a starter, even though they list it as one. It is a p.i.t.a. if you don't get the length right on the money.
If you want a "big" pen, ask Larry about the Perfect Fit convertible ballpoint/pencil. It is the easiest-to-make large pen I have tried...as simple as the 7mm slimline, and much more appealing to make, hold and use.
Couple of questions.
>Thanks ALL for the input.
I'll put my fingers to work tomorrow calling and surfing these sites. I just got a Packard and Penn States catalog tonight when I got home. I work second shift.
Question #1. What size(s) of pens and pencils are most popular? i.e. easiest to find parts for?
Question#2. Do I need any "special" kind of skew-ahhh-tool thingy? Or should I just go at it with the generic tools I have?
Thanks for your time all, I'm sorry I'm such a P.I.T.A. but ya gotta get the skinny from those in the know. :)
Doug
Greg W. in NC
>Doug,
As has been mentioned, Bill Baumbeck (Arizonasilouette.com) is an excellent source! Note that he resells Craft Supplies and Berea kits....except you can save by buying from him, as he will discount their prices.
Another reseller you need to check with is Ryan Polokoff, with Woodturningz.com. Like Bill, he can save you a few bucks. He resells PSI stuff. I buy from both of these guys (and a lot, I might add), and can highly recommend them. They'll help you out with what you need to begin (Bill even has a 'how to' video on pens.)
No, you don't need any specific tools just for pens. My preferred tool is the skew, but many use spindle or bowl gouges (I would recommend a spindle gouge, especially for beginning.)
Note that you'll need a mandrel, but not all mandrels fit other manufacturer's kits. For example, the PSI mandrel is the smallest, and most other kits will fit on it, but they might be a bit 'sloppy' or loose. However, the Berea mandrel is the thickest of the 7mm mandrels, but you will probably have to ream out most of PSI bushings before they'll even fit on the Berea mandrel. Personally, I think the Berea mandrel is the best by far, and you might want to start with it, and buy their kits for compatibility sake, unless you're wanting to ream out bushings that won't fit it.
You will need a Gouge
Dustmaker Mike
>to rough out the blanks. I use a 1/2 roughing gouge to do it. Just keep it sharp and any one will work for ya. Buy new turning tools as you find a need for them and get a better feel of what you are going to do the lots of. Have Fun
Re: Couple of questions. *LINK*
Russ Fairfield
>Read the pen making instructions on my website, and order some SlimLine pen kits. Also recommend that you get one of the videos that are available, either mine or you can order Bill Baumbecks video when you order the pen kits.
Have fun!!
Making a Pen
Gary Land
>I know that HF is not exactly a primo place to get tools, but HF had a HSS turning set for about 39.00. I think that it might be a starter set. Also as for turning penkits you might want to try the folloewing places. Penn State Industries, Berea Hardwoods, and a new one that I just found is Pens of Color. These places seem to have good prices. Hope that this helps
