ADVERTISE HERE - FREE TRIAL
Wood Find & Questions *long*
Ryan McMullen
>Well, going home from work the other day I noticed some wood laying on the side of the road, neatly covered by tree limbs and branches. Yesterday as I was going to work, I slowed down to see if I could see what the wood was. It looked like Cherry, and nice sized pieces at that, so I decided that at lunch I would go a and save a few pieces from the Memphis landfill. Well, they are not cherry, but rather cedar, the kind that has that wonderfull cedar smell. So I grabbed a 3 logs, no easy task as these logs were 27" long and averaged 16" in diameter. So last night I spent the evening cutting up the logs and sealing them.
This one shows the 3 logs. They had some bad checking but I figured that they were long enought that I could cut it away and have good wood.
Here is a view with the CS sitting on the logs. To give some scale the CS is an 18" poulan.
And here is the pile of Cedar after cutting.
Now a question or 2. I noticed while sealing the pieces of cedar that they were already starting to crack - it it common for cedar to crack this fast? I'm hopeing I will get some workable wood out of this. And should I rough turn these pcs or finish turn?
Thanks for lookin'
Ryan
Re: Wood Find & Questions *long*
Glenn Hodges
>Yep, cedar will crack fast. I always carry Anchorseal to the woods with me when I cut down a tree. Cedar is nice wood, and I think you will enjoy it if you have never turned any. If you really want to do something unusual try doing one of these in a natural edge bowl. Good luck, good salvage.
Nashville, GA
RPE
>I've turned alot aeromatic cedar like you have, and the same size. It turns great. The knots are usually tight. I have had water sling out of the bowls while turning them.
I turn them to completion when I turn them. If you do this, your sandpaper will clog real bad on the first sanding. The wood will dry real fast as you sand. Stop and look for hair line cracks as you sand and turn. When you see one, CA it and let it set for a minute or so, or use an accelerator.
I usually turn to a 1/4" or so. If you experience tear out, don't worry about it. It sands real easy. You can almost shape the bowls with sandpaper.
Yes it makes a lot of dust! especially when it is dry. By the time you take it through the grits it will be dry.
Keep an eye on your sandpaper clogging. If it clogs (and it will) on the first grits, it will burnish (burn) the wood and look bad. I use a compressor on the sandpaper to clean it while sanding to clear it. When It will no longer clear, I pitch it and get new paper.
One last thing, make the fixing large as you can on the bottom. i.e. 3". Sometimes the smaller fixings just don't have enough mass to support the cutting and they seperate off.
Hope this helps.
RP
Ryan McMullen
>Thanks for the info. Hopefully, if all goes well, this weekend is going to be a weekend full of turning (with a little bit of fishing thrown in).
Ryan
Ryan, You and Chuck...
Clem Wixted Jonesboro, AR
>... find some great wood as you cruise the streets of Memphis :-)
Clem
