Tip of the Week
Tip of the Week
Tip of the Week
TDaniel
>Many of us use the Sioux or Milwaukee close quarter drills for sanding. With heavy use the rear bearing tends to fail a bit too soon for some of us. I was at the Milwaukee Service Center yesterday to buy a bearing and I asked if a better bearing was available for the dusty environment. He said that the stock bearing was a shielded bearing but for $3 more I could get a sealed bearing. The part number for the sealed bearing is:
EE 1 1/2 2RSM3GSR.
TD
Re: Tip of the Week
Re: Tip of the Week
Mark Kauder, Phenix City, AL
>Great - Thanks TD
Re: Tip of the Week
Re: Tip of the Week
Greg W. in NC
>Terry,
Great info! Do you know if this is the right part number for all of the Milwaukee close quarter drills? (specifically, the one I got from you?) Thanks!
Re: Tip of the Week
Re: Tip of the Week
>NO - if you got it from TD - you need to send an extra $10 directly to TD. ;)
Mark
Re: Tip of the Week
I think so
TDaniel
>This number is not a Milwaukee number but a bearing number; any bearing company should be able to supply it. Milwaukee has just made some changes to the drill so I cannot say for certain that it is the same bearing. I think the main changes were to the switch and the cooling vents.
Re: Tip of the Week
Re: Tip of the Week
Greg W. in NC
>You mean on top of the $249 I already paid for the rebuilt drill? ;-)
Kidding Terry! For the record, I'll say that I've been more than pleased with Terry's dealings....great guy, and I will say "you can buy with confidence from him!" (now Terry, can I have that "mini" bowl you had at the meeting on Saturday???)
Re: Tip of the Week
The little 34" one? Sure.
TDaniel
Re: Tip of the Week
yeah, that one!
Greg W. in NC
>I figure, a drain hole, couple of spouts for the water jets, and voila! "Natural" hot tub! :-)
Re: Tip of the Week
And you can say...
TDaniel
>You have the most expensive hot tub on the block.
