Veritas - Innovation in Tools
I did a search first - drying burl caps
Mike Schwing from Md.
>Came up pretty empty, searched on "drying burl" for the past year.
So now I'm asking. A friend has managed to score a number of BEAUTIFUL fresh cut cherry burl caps for me, up to about 15" diameter.
How do I not ruin this wood?
Some of them I'd like to turn like a normal bowl, inspired by some of your guys natural edge burl work, and others I'd like to do more like this one...
But in either case, I'd very much appreciate some guidance. Right now they're rain soaked and fresh cut. Up to 5" thick.
I've read that normal roughing/dry/finishing sequences don't work so great on burl. No way is Mrs. Schwingding gonna let me put them in the pressure cooker, as I've read about that as well.
Just set them aside and let'm dry? Turn the bowl to finish wet? They're too pretty just to let me at them with no clue.
Thank you.
Re: I did a search first - drying burl caps
Brad Vietje
Brad Vietje
>Mike,
In my experience with Black Cherry, the burl is much easier to dry than the straight grained wood. I usually turn them green, leaving a shrinkage allowance, wax them (paste wax or Anchorseal), and then finish turn them later, when dry. I worry much more about the straight grain than the burl, where cracks are more likely. Cherry burls can be kept waxed up for quite a while.
Safe Spinning,
Brad Vietje
Thetford, VT
Wally Dickerman at Green Valley, Az.
>I've had no experience with cherry burl. (Wish I did) However, I've had lots of experience with maple, madrone and myrtlewood burls. Burl is easier to dry and usually has less distortion than plain wood. Madrone is the exception. (It's the most unstable wood in North America) I suggest that you coat the exposed wood heavily with anchorseal, then rough turn it and coat it again while it dries.
Wally
Burl caps
Bob Hackett
>While burl caps will dry they also tend to honeycomb if not waxed well.Cherry burls have alot of voids and bark inclusions and this seems to be where the major cracks work the most damage.If you don`t mind filling voids and checks then dry them as is.This holds true with New England cherry burl,I can`t say if your burl will do the same or not.
The other thing to consider is that you have an option to add alittle surprise to your work if you turn burl while still relatively green.Once you finish sand you can set the work aside to dry and the surface will take on a bumpy type of texture that most folks find delightful.I`ve had people tell me it feels like rawhide or that it feels alive under thier fingers.Microwave drying the work seems to intensify the effect.You get just the hint of the feel of the graining that makes burl so irresistable to most people.
E-mail if you want more info on turning cherry burl.BTW-it`s one of my best selling woods,BE and curly maple are the others.
Mainely,Bob
John Williams in PA
>I have found that cherry burl dries nicely with time and tends not to check if you cut away the remnants of the branch or trunk on which it grew. If you do not do this, that wood may tend to check and the check carries through to the burl. So either get rid of it or coat with end grain sealer.
The other thing is that even when the burl is dry, the wood tends to move after turning. I believe this is because the stresses in the piece are released with removal of the waste wood. So if you want perfect rounds, then plan on twice turning them as you would if the wood was wet.
Hi John!
Gary Evans
>Nice to see your name back on the board. I was wondering the other day how you are doing.
GE
Hi Gary...doin' fine...
John Williams in PA
