Bandsaw safety
Bandsaw safety
Keith Tompkins
Bandsaw safety
Keith Tompkins
>Sean and Mike have both recently posted regarding bandsaw accidents.
Sean's injury was probably preventable.....He was cutting a hard piece of wood with a DULL BLADE; as he stated it was ready to be replaced.
A dull blade requires much more pressure in order to cut. When a slip occurred, a bad injury resulted. This probably would not have happened with a sharp blade.
Also, especially with small pieces, it is possible to start a cut, and then reach BEHIND the blade, and pull the piece through the blade. There is almost no chance of the blade hitting your hand at the end of the cut.
hope this helps.......get well, Keith
Re: Bandsaw safety
Re: Bandsaw safety
Mike Schwing from Md.
>As a result of my injury, I have altered my technique to include several of the suggestions given here recently. Most notably keeping a finger or two on the edge of the table so the hand can't possibly reach into the blade, and the other being to move behind the blade and pull the piece through to completion.
I don't think what I was doing was remarkably unsafe but it certainly could have been improved upon. On hindsight, complacency had probably set in as I'd done basically the same thing hundreds of times without incident.
When I was learning to use the tablesaw I had a kickback injury that threw a 4 inch piece of bloodwood directly at my chest - it probably should have stopped my heart. It totally collapsed my left pectoral muscle for several days, and I had a very clear indentation of the corner of that wood in my chest. That accident kept me away from the table saw until I was certain I wouldn't make the same (dumb) mistake again. Nobody had taught me table saw do's and don'ts, so I learned them the hard (and almost fatal) way. That wasn't the case here as I had a lot of bandsaw experience but just like the tablesaw incident - it has given me a healthy dose of respect for the tool that I didn't have before.
I'm sure glad I still have my finger, that 3tpi blade doesn't really cut cleanly in flesh like it does in wood. Nasty looking.
Re: Bandsaw safety
Re: Bandsaw safety
Sean Troy
>You can bet I'll use my band saw as described in recent posts from now on. I will also keep a good blade on the saw. Trying to get that extra mile out of a cutting impliment is just not worth it. I,ve gone over 25 years without an accident using power tools and it took one time of not doing what I should have, to allmost lose two fingers .I was very lucky that it was not a lot worse. There is a lot of great advise posted on this forum and thats why I visit here so often. I can only hope the rest of you will pay more attention than I did . Well, I now have plenty of time to go through all my tools and clean, lube and adjust them. Thanks to all for the great advise and I WILL heed it all. Thanks, Sean
Re: Bandsaw safety
Re: Bandsaw safety
David Eaves
>All the posts on bandsaw safety have been really useful I have picked some good tips up. I don't have one yet but know I need one even if I don't like them.
Hope those with injuries heal soon
David
Re: Bandsaw safety
Keith Tompkins
Re: Bandsaw safety
Keith Tompkins
>At a former place of employment, I was responsible for training new people to run equipment. BIG equipment. 25 horsepower bandsaws.....a Unisaw would look like a toy in that environment.
People would run a bandsaw all day, cutting palletloads of furniture parts. The worst part was boredom....that's when an accident can happen.
Practice safe procedures, ask yourself...is this a proper procedure? Kinda like measure twice, cut once.
Ever see a bandsaw blade break on a 36" bandsaw? It will scare the bejeebers out of you!
Re: Bandsaw safety
36" shipsaw
Bob Hackett
>Had a 2" wide blade break at the weld.The one end hit the table about an inch from my hand and bowed out hard enough to rip the upper guard off and send it flying.I went home early that day.
Mainely,Bob
Re: Bandsaw safety
Re: Bandsaw safety
Darrell Feltmate
>I use a band saw a lot. Mine is over 20 years old and no injuries (knock on wood). One obvious thing no one has mentioned is simply to use a push stick when ever possible. "oops, I cut some wood" sounds a lot better than "ouch."
Re: Bandsaw safety
Re: Short Version
>Put brian in gear before putting saw in motion.
Be Safe
Re: Bandsaw safety
Re: Shorter Version
>"brain"
Re: Bandsaw safety
Re: Bandsaw safety
Peter Teubel
>Keith wrote:
"Ever see a bandsaw blade break on a 36" bandsaw? It will scare the bejeebers out of you!"
I've broken a few on my 20" bandsaw. Yup, it DOES get your attention!
Re: Bandsaw safety
Re: Shorter Version
Peter Teubel
>Oh...I thought "brian" was your apprentice.
Re: Bandsaw safety
Whew!
Bob Hackett
>You obviously have no idea how hard it is to get Brian in gear.It`s hard enough just kickstartin` the guy.:^)
Mainely,Bob
