Chainsawing question
Harvey Bernstein (Philly)
>Do I have a sharpening problem, a technique problem, or both.
I sharpen the teeth on my Husqy 350 18" bar using a "sharpforce" , which files at 30 or 35*, and I use 0* vertical. The teeth feel sharp when I'm finished. I do get square chunks when I crosscut and long shavings when I ripcut rounds. I am using a sawbuck.
Today while crosscutting some ~6" rounds(white oak I think), the chain grabbed the rounds and yanked them towards me (nearly coming over the sawbuck). This happened a few times.
A couple of times I started cutting w/ the chain on the round and figured that that was a technique problem, but a few times I started the chain 1st and then hit the wood w/ the chain spinning and it still happened.
So, any educated guesses as to why the saw is pulling the wood with the info I've given?
Thanks in advance,
Harvey
remove 'remove' for email
