Gluing stained wood.
J.Smith
>Does anyone know if wood glue will stick to the
surface of wood that has been stained with a water base stain? I want to make a segmented bowl and need some almost "black" wood.
Re: Gluing stained wood.
Joel Hunnicutt
>When I need really black wood, I wipe it with india ink after turning. I don't think you would get good enough penetration of the dye to try and dye it before turning.
>I agree with Joel. I tried dying my own wood and couldn't get it to penetrate more than 1/16 on the side grain so as soon as you start turning you lose the color. You can paint up to the wood you want to stain with lacquer or shellac and then stain just that area.
J.Smith
>The piece I wanted to stain would be a pre-turned and finished rim ring that would glue on top edge of bowl and hopefully only require light sanding to complete finishing.
>That works great. We have a turner in our club that does that all the time and I believe he just uses titebond ll. I think as long as you don't have a slick finish or wax on the piece before gluing you will be OK.
Mark Kauder, Phenix City, AL
>Since you explained lower in the thread what you want to do, I will put my two cents worth in.
I would suggest if you want a black rim on the bowl:
1) use a dark wood to begin with - Walnut comes to mind.
2) Put a layer of black veneer between the bowl and the segmented rim
3) sand and finish the bowl to completion.
4) moisten the wood so as to raise the grain
5) sand again
6) now apply your black dye to the wood carefully - with the veneer in place, you now have a small barrier between the rim and the body of the bowl - this and the glue lines will keep the dye from migrating/wicking into the lighter colored wood. As others have mentioned, India Ink is probably the best really black dye that you will get.
7) after completely drying, apply several coats of finish to seal in the black before knocking off the nibs with a fine sandpaper.
Mark
JSmith
>Thanks. I'm going to give it a try.
