sanding drum piece
sanding drum piece
sanding drum piece
>Mark
This is a piece my freind Everett Elkins carved. He roughed out the grooves and then fine tuned and shaped them using a 1" sanding drum similar to the one I use for large flutes.
Re: sanding drum piece
John Trant (aka Boxes-n-Bowls)
>Do you have a side view photo? I cannot tell if the carving is on the top of the rim or along the sides. It looks beautiful, nevertheless.
John
>It is sort of a platter with the grooves running at an angle across the outer edge. I will look and see if I have a side angle of the piece. I shot it in place in a show and don't remember if I shot individual shots. Everett Produces the most unique and beautiful pieces every month.
Bob M
>WOW, that is awesome. You really raised the bar with that piece.
